λ garuda-inxi
Kernel: 6.0.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a4968043-72e2-4b8d-ba90-5244fd6f0113 rw rootflags=subvol=@
resume=UUID=6dd892a9-c839-493a-90e9-c0b83769015f loglevel=3
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: System76 product: Thelio Major v: thelio-major-r2.1
Mobo: System76 model: Thelio Major v: thelio-major-r2.1
serial: <superuser required> UEFI: System76 v: FCa Z5 date: 12/23/2021
Info: model: AMD Ryzen Threadripper 3960X bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x31 (49) stepping: 0 microcode: 0x8301055
Topology: cpus: 1x cores: 24 tpc: 2 threads: 48 smt: enabled cache:
L1: 1.5 MiB desc: d-24x32 KiB; i-24x32 KiB L2: 12 MiB desc: 24x512 KiB
L3: 128 MiB desc: 8x16 MiB
Speed (MHz): avg: 3791 high: 3800 min/max: 2200/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3591 6: 3800 7: 3800 8: 3611 9: 3800 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800
20: 3800 21: 3800 22: 3800 23: 3800 24: 3800 25: 3800 26: 3800 27: 3800
28: 3800 29: 3800 30: 3800 31: 3800 32: 3800 33: 3800 34: 3800 35: 3800
36: 3800 37: 3800 38: 3800 39: 3800 40: 3800 41: 3800 42: 3800 43: 3800
44: 3800 45: 3800 46: 3800 47: 3800 48: 3800 bogomips: 364121
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: PNY driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 21:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-2.1:5
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.57x13.46")
s-diag: 872mm (34.33")
Monitor-1: HDMI-0 res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 1-1.1:3 chip-ID: 1532:051a pcie:
class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 21:00.1
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 23:00.4 chip-ID: 1022:1487
Device-3: Razer USA Nari Ultimate type: USB
Device-4: Logitech BRIO Ultra HD Webcam type: USB
Device-5: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-5:3 chip-ID: 0414:a00d
Sound API: ALSA v: k6.0.1-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 9000 bus-ID: 44:00.0
IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 45:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo2 state: down mac: <filter>
bus-ID: 7-5:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 5.46 TiB used: 1.77 TiB (32.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 40.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 603.13 GiB
(33.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 308 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 603.13 GiB
ID-4: /var/log raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 603.13
GiB (33.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 603.13
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.31 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 55.2 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 674 Uptime: 3h 56m wakeups: 6 Memory: 31.19 GiB used: 6.44 GiB
(20.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1945 libs: 537
tools: octopi,paru Shell: fish v: 3.5.1 default: Zsh v: 5.9
Garuda (2.6.8-1):
System install date: 2022-09-05
Last full system update: 2022-10-13 ↻
Please report in detail everything you have already attempted to solve your problem:
After updating to kernel 6.0.1-zen1-1-zen,
I see the following error when i run garuda-update
garuda is up to date
core is up to date
extra is up to date
community 7.0 MiB 8.50 MiB/s 00:01 [------------------------------------------------------] 100%
multilib is up to date
chaotic-aur 2.3 MiB 1503 KiB/s 00:02 [------------------------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 94.7 KiB 185 KiB/s 00:01 [------------------------------------------------------] 100%
core 157.0 KiB 774 KiB/s 00:00 [------------------------------------------------------] 100%
extra 1724.5 KiB 3.65 MiB/s 00:00 [------------------------------------------------------] 100%
community 7.0 MiB 5.14 MiB/s 00:01 [------------------------------------------------------] 100%
multilib 171.1 KiB 687 KiB/s 00:00 [------------------------------------------------------] 100%
chaotic-aur 2.3 MiB 1429 KiB/s 00:02 [------------------------------------------------------] 100%
spawn pacman -Su
warning: bottles: local (1:2022.5.28-5) is newer than chaotic-aur (2022.9.28.1-1)
there is nothing to do
Checking for plugin updates
Nothing to install / update
System updated! 🐧
Thoughts? Thanks!
