Hello.
Ok I just installed Guarda linux to get back into linux however my offbrand(however still linux supported) from https://sunwaytek.com/ just causes a kernal panic and freezes the entire system when plugged in, this controller seems to work on just about every other distro(debian based distros) so far so this should work with out the catastrophic meltdown.
Steps I tried to fix it with:
1.Official arch Linux wiki game-pad page didn't seem to be useful
2.Reinstalled generic controller drivers with the [Gaurda Gamer] app thing
3. Checked /var/logs for logs... most were empty as this is a brand new install
4.Googled where kernel panic logs live specifically on arch Linux with no clear results....
tldr: I'm asking where relevant logs might be or any packages that might be needed are for fixing my controller kernel panicking?
root=UUID=44f65648-4600-4c26-8ba1-4987421590f8 rw rootflags=subvol=@
Type: Laptop System: Dell product: Dell G15 5511 v: N/A
Mobo: Dell model: 0284MK v: A01 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 02/17/2022
ID-1: BAT0 charge: 84.0 Wh (100.0%) condition: 84.0/84.3 Wh (99.6%)
volts: 13.0 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly
serial: <filter> status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x3C
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1943 high: 4299 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 1676 2: 4284 3: 801
4: 2279 5: 2510 6: 1564 7: 4299 8: 801 9: 1291 10: 800 11: 801 12: 1144
13: 3242 14: 1637 15: 2013 16: 1956 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-3,DP-4,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2560
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-5:2 chip-ID: 0c45:6720 class-ID: 0e02
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0xae8b built: 2020 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.0.1
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 2d:00.0 chip-ID: 10ec:2600
IF: enp45s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 39.02 GiB (4.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41001131
temp: 36.9 C scheme: GPT
ID-1: / raw-size: 317.53 GiB size: 317.53 GiB (100.00%)
used: 38.81 GiB (12.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 250 MiB size: 246 MiB (98.40%)
used: 222.2 MiB (90.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 317.53 GiB size: 317.53 GiB (100.00%)
ID-4: /var/log raw-size: 317.53 GiB size: 317.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 317.53 GiB size: 317.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.37 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 338 Uptime: 5m wakeups: 149 Memory: 15.37 GiB
used: 2.86 GiB (18.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1701 lib: 512 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.6.1-1):
System install date: 2022-04-06
Last full system update: 2022-04-06
