Kded6 ask for password and deactivate wifi
My other notebook has Windows/Garuda, all seems ok, but always ask for kded6 password and deactivate wifi.
I search in forum topics, but I cannot find anything. Any help?
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=364e8863-f3fc-4205-aebc-4a4bc5f84c9d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: Dell product: Precision 3530 v: N/A
Mobo: Dell model: 0C38P6 v: A00 serial: <superuser required> part-nu: 0820
uuid: <superuser required> UEFI: Dell v: 1.36.0 date: 11/06/2024
ID-1: BAT0 charge: 74.5 Wh (100.0%) condition: 74.5/92.0 Wh (81.0%)
volts: 12.4 min: 11.4 model: SMP DELL WFWKK65 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Coffee Lake
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
ports: active: eDP-1 empty: DP-7, DP-8, DP-9, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P600 Mobile] vendor: Dell driver: nvidia
v: 570.124.04 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-1, DP-2,
DP-3, DP-4, DP-5, DP-6 bus-ID: 01:00.0 chip-ID: 10de:1cbc class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 0c45:6717 class-ID: 0e02
display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x06f1 built: 2016 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
modes: 1920x1080
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia
wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
GT2) device-ID: 8086:3e9b memory: 15.2 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: N/A device-ID: 8086:3e9b
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: Quadro P600
driver: N/A device-ID: 10de:1cbc surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api with: aoss
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 476.94 GiB used: 23.99 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200S NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 22001070 temp: 46.9 C
ID-1: / raw-size: 232.68 GiB size: 232.68 GiB (100.00%)
used: 23.93 GiB (10.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 56.6 MiB (58.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.68 GiB size: 232.68 GiB (100.00%)
ID-4: /var/log raw-size: 232.68 GiB size: 232.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.68 GiB size: 232.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.13 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C pch: 64.0 C mobo: N/A
Memory: total: 32 GiB available: 31.13 GiB used: 4 GiB (12.9%)
Processes: 303 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1835 libs: 542 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.0
System install date:     2025-03-06
Last full system update: 2025-03-07
Do you have auto login enabled?
If so this is the cause If i understand what your asking correctly.
to stop your computer asking for a wifi password
1 right click on connection icon in your system tray.
2 press on configure network connections
3 press on the security tab of your wifi connection
4 store pass word for all users to allow anyone online
or
5 store pass word or for your own usage only
or
6 ask for a pass word each boot.
@elite Yes, I have autologin. But with steps of @Jeshu the problem disappear.
Also, I installed kwwalletmanager and I can manage kwallet password blank in order to not ask for passwords.
Thank you all.
