KDE top panel : icon switch user-logout-shutdown... Disapeared
Hey all…
No very important but the switch user-logout- shutdown… button (normally in the top right corner i missing… The one with the user’s image…
Is it me (as usual) or is it a problem after an update ?
I tried to install the widget again, but i cant find his name…
My inxi (not sure if it’s needed…
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5a2ed686-9f3f-4d1c-a51e-41bbeea7c18c rw rootflags=subvol=@
splash pcie_aspm=off ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Convertible System: LENOVO product: 20FRS08T00
v: ThinkPad X1 Carbon 4th serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 20FRS08T00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1FET81W (1.55 )
date: 10/11/2022
ID-1: BAT0 charge: 47.4 Wh (100.0%) condition: 47.4/47.4 Wh (100.0%)
volts: 16.6 min: 14.8 model: LGC 00HW028 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 537 high: 697 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 697 2: 400 3: 651 4: 400
bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 04f2:b531
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Monitor-1: eDP-1 model: LG Display 0x04aa built: 2015 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.32 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF-ID-1: wwp0s20f0u2c3 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0000
Local Storage: total: 1.15 TiB used: 211.67 GiB (18.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SN01T size: 953.55 GiB
block-size: physical: 512 B logical: 512 B type: Removable tech: SSD
serial: <filter> scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKGF240A5L
tech: SSD serial: <filter> fw-rev: LV8i scheme: GPT
ID-1: / raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
used: 28.11 GiB (26.9%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 502 MiB size: 501 MiB (99.80%)
used: 600 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-4: /var/log raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 45.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 208 Uptime: 57m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.49 GiB used: 3.11 GiB (41.5%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1477
pm: pacman pkgs: 1474 libs: 435 tools: octopi,paru pm: rpm pkgs: 3
Shell: fish v: 3.7.0 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2022-12-02
Last full system update: 2024-01-12
My bad… I have the bad idea to remove orphans… :sob: :sob: :sob:
Here’s the list :
cmake                       3.28.1-1              -72.14 MiB
cppdap                      1.58.0-1               -1.62 MiB
kdsoap-qt6                  2.2.0-1                -1.28 MiB
ninja                       1.11.1-3               -0.35 MiB
perl-alien-build            2.80-2                 -0.73 MiB
perl-alien-libxml2          0.19-2                 -0.01 MiB
perl-capture-tiny           0.48-7                 -0.03 MiB
perl-dbi                    1.643-6                -2.23 MiB
perl-ffi-checklib           0.31-3                 -0.03 MiB
perl-file-chdir             0.1011-5               -0.01 MiB
perl-file-which             1.27-3                 -0.02 MiB
perl-path-tiny              0.144-2                -0.14 MiB
perl-xml-libxml             2.0209-1               -1.80 MiB
perl-xml-namespacesupport   1.12-5                 -0.02 MiB
perl-xml-sax                1.02-1                 -0.10 MiB
perl-xml-sax-base           1.09-5                 -0.16 MiB
python-tqdm                 4.66.1-2               -0.65 MiB
python-typing_extensions    4.9.0-1                -0.37 MiB
re2                         1:20231101-1           -0.40 MiB
rhash                       1.4.4-1                -0.32 MiB
appstream-glib              0.8.2-3                -3.74 MiB
dbus-glib                   0.112-3                -0.80 MiB
docx2txt                    1.4-5                  -0.02 MiB
electron25                  25.9.8-1             -212.73 MiB
electron26                  26.6.5-1             -219.18 MiB
extra-cmake-modules         5.113.0-1              -1.96 MiB
foomatic-db-engine          4:20220521-1           -0.79 MiB
foomatic-db-nonfree         3:20230903-1           -0.21 MiB
gptfdisk                    1.0.9-2                -0.66 MiB
kdeplasma-addons            5.27.10-2              -5.66 MiB
kdsoap-ws-discovery-client  0.3.0-2                -0.88 MiB
liblouis                    3.28.0-1              -12.74 MiB
libxvmc                     1.0.13-2               -0.09 MiB
meson                       1.3.1-1               -13.36 MiB
wayland-protocols           1.32-1                 -0.52 MiB
Is it kdeplasma-addons the guilty ?
Quite likely, and the file listing confirms: Arch Linux - kdeplasma-addons 5.27.10-2 (x86_64) there’s plasma_applet_org.kde.plasma.userswitcher stuff
That did the trick… Thanks meanruse… :+1: :+1: :+1:
