I’m using the Dragonized version of Garuda. I was messing around trying to get menus to appear in KeepassXC and I somehow messed up my whole Garuda theme. The KDE button along with all the panels, menus, and desktop are gone. If I right-click on the desktop, I see nothing. The wallpaper is also missing.
I’ve searched everywhere and I can’t find this specific problem. There are mentions of individual panels and buttons missing, but nothing about KDE being completely broken. The only reason I can run anything at all is because I happened to have a terminal opened at the time.
First I tried to go into Garuda Assistant and reset all settings, but that did nothing at all. Then, I tried restoring a snapshot using snapper, but that only half-works; some of the theme is restored, like the start button, but the window decorations are all messed up. If I try to go into System Settings and try to change the “Window Decorations,” the KDE menu and all the menu bars disappear again.
I also tried to reinstall the dragonized theme with pacman -S garuda-dr460nized
, which also doesn’t work.
How do I fix this? garuda-inxi output follows…
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=79bebd74-6c02-4148-b1e5-1bed3e4c4274 rw rootflags=subvol=@
quiet resume=UUID=03ba1005-a576-46de-bba3-38f9d149082e loglevel=3 ibt=off
wm: kwin_wayland vt: 5 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASRock model: B550 Taichi Razer Edition
Megatrends LLC. v: L3.46 date: 08/20/2024
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4539 min/max: 550/4550 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4539 2: 4539 3: 4539
4: 4539 5: 4539 6: 4539 7: 4539 8: 4539 9: 4539 10: 4539 11: 4539 12: 4539
13: 4539 14: 4539 15: 4539 16: 4539 bogomips: 108604
Device-1: Intel DG2 [Arc A770] vendor: ASRock driver: i915 v: kernel
alternate: xe arch: Xe-HPG code: Alchemist process: TSMC n6 (7nm)
built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-1
off: HDMI-A-4 empty: DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 0e:00.0 chip-ID: 8086:56a0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900
XT/7900 XTX/7900 GRE/7900M] vendor: Yeston driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-5,HDMI-A-5
empty: DP-6,DP-7,Writeback-1 bus-ID: 12:00.0 chip-ID: 1002:744c
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,intel,vesa dri: iris,radeonsi
gpu: amdgpu,i915 display-ID: 0
Monitor-1: DP-1 model: MULTIVIEWER built: 2019 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 79 gamma: 1.2 size: 1600x900mm (62.99x35.43")
diag: 707mm (27.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: DP-5 model: MULTIVIEWER built: 2019 res: 1920x1080 dpi: 79
gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 707mm (27.8") ratio: 16:9
Monitor-3: HDMI-A-4 model: MULTIVIEWER built: 2019 res: 1920x1080 dpi: 79
Monitor-4: HDMI-A-5 model: MULTIVIEWER built: 2019 res: 1920x1080 dpi: 79
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A770 Graphics (DG2)
device-ID: 8086:56a0 memory: 15.53 GiB unified: no display-ID: :3.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: Intel
Arc A770 Graphics (DG2) driver: N/A device-ID: 8086:56a0
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: AMD Radeon
RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
Device-1: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0f:00.0 chip-ID: 8086:4f90
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 12:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 14:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 05:00.0 chip-ID: 8086:3102 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7.3.3:16
IF: enp2s0f0u7u3u3 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0029
Local Storage: total: 3.68 TiB used: 523.86 GiB (13.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NX-2TB 2280 size: 1.86 TiB
tech: SSD serial: <filter> fw-rev: H240129a temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SanDisk model: Extreme 2TB X3N
lanes: 4 tech: SSD serial: <filter> fw-rev: 731100WD temp: 40.9 C
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 523.86 GiB (28.5%)
used: 523.86 GiB (28.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 68.99 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 62.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 70.8 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 42.0 C
Fan Speeds (rpm): fan-1: 0 gpu: amdgpu fan: 0
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 5.82 GiB (9.3%)
Processes: 445 Power: uptime: 24m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.08 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1953 libs: 578 tools: octopi,paru,pikaur
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-12-03
Last full system update: 2025-01-25
