Hello,
I was not able to delete the tags in kde.
Garuda-inxi
╭─user@localhost in ~ took 10s
╰─λ garuda-inxi
Kernel: 5.16.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=28b9bda0-b454-461f-9c95-d6e1a406bed4 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
kernel
bus-ID: 2-1.5:6 chip-ID: 05c6:f00e class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 465.76 GiB used: 180.45 GiB (38.7%)
model: WD5000AZRX-00L4HB0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 30.13 GiB (23.5%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /home raw-size: 128 GiB size: 128 GiB (100.00%)
used: 30.13 GiB (23.5%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-3: /var/log raw-size: 128 GiB size: 128 GiB (100.00%)
ID-4: /var/tmp raw-size: 128 GiB size: 128 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 200 Uptime: 17m wakeups: 0 Memory: 3.71 GiB
used: 1.94 GiB (52.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1688 lib: 371 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-26
Last full system update: 2022-03-11
Is partially upgraded: Yes
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
Visited :
KDE forums
I was able to enter the folder where the tag existed but can't change the sticky bit and even as a root
but cannot be able to delete them
Visited :
KDE forums
In konsole
╰─λ cd /run/user/1000/kio-fuse-KskKzX/tags
╭─user@localhost in /run/user/1000/kio-fuse-KskKzX/tags took 1ms
╰─λ ls
drwx------ - user 23 Mar 19:39 Physics
╭─user@localhost in /run/user/1000/kio-fuse-KskKzX/tags took 38ms
╰─λ rmdir /run/user/1000/kio-fuse-KskKzX/tags/Physics/
╭─user@localhost in /run/user/1000/kio-fuse-KskKzX/tags took 15ms
╰─λ ls
drwx------ - user 23 Mar 19:40 Physics
╭─user@localhost in /run/user/1000/kio-fuse-KskKzX/tags took 3ms
╰─λ _
I Don't know much of kde's so please suggest any possible solution(s)
