KDE dock shortcuts not working
Hi there
Since a week ago all the KDE panel dock shortcuts do nothing (not Latte), neither the applications widget and some system tray shortcuts like night color control (won't open related system settings on click).
I click them but nothing happens. Tried making a new dock panel to try, no luck. Don't know if that's related but I can't see either icons on desktop (I've got the option enabled).
Meanwhile I'm using Krunner and the terminal to launch apps, but I'd love to know what's going on.
Thank you in advance.
Kernel: 6.2.8-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
root=UUID=99d14c88-b1e3-48f2-8bb8-be8ca898c637 rw [email protected]
quiet splash rd.udev.log_priority=3 nvidia-drm.modeset=1
vt.global_cursor_default=0 loglevel=3 nvidia-drm.modeset=1
mitigations=off usbcore.autosuspend=-1 btusb.enable_autosuspend=0 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z390 AORUS ULTRA v: N/A
Mobo: Gigabyte model: Z390 AORUS ULTRA-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F10h
date: 01/19/2021
ID-1: hidpp_battery_0 charge: 68% condition: N/A volts: 3.9 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2611 high: 5001 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 1266 2: 1017 3: 5000
4: 965 5: 1924 6: 964 7: 1802 8: 5001 9: 5000 10: 5000 11: 1165 12: 1216
13: 1738 14: 3536 15: 1637 16: 4546 bogomips: 115200
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ZOTAC
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-2,DP-3 empty: DP-1,HDMI-A-1,Unknown-1
bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 5120x1440 s-dpi: 80 s-size: 1624x457mm (63.94x17.99")
s-diag: 1687mm (66.42")
Monitor-1: DP-2 note: disabled pos: primary model: Samsung LC49G95T
serial: <filter> built: 2020 res: 5120x1440 hz: 120 dpi: 130048 gamma: 1.2
size: 1x1mm (0.04x0.04") diag: 1239mm (48.8") modes: max: 3840x1080
min: 640x480
Monitor-2: DP-3 mapped: DP-4 note: disabled model: LG (GoldStar) 34GK950F
serial: <filter> built: 2019 res: 5120x1440 dpi: 109 gamma: 1.2
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
bus-ID: 2-10:2 v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: ff01:000c class-ID: 0300 bus-ID: 00:1f.3 chip-ID: 8086:a348
serial: <filter> class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus-ID: 05:04.0 chip-ID: 13f6:8788
class-ID: 0401
Device-4: MV-SILICON K38 type: USB driver: snd-usb-audio
API: ALSA v: k6.2.8-1-cachyos-bore status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 2-14:8 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 6.77 TiB used: 4.98 TiB (73.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM12.1 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 37.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
type: SSD serial: <filter> rev: 00RL scheme: MBR
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
used: 778.02 GiB (83.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 31.28 GiB used: 14.65 GiB (46.8%)
System Temperatures: cpu: 44.0 C pch: 47.0 C mobo: N/A gpu: nvidia
temp: 38 C
Fan Speeds (RPM): fan-2: 1513 fan-3: 1501 fan-4: 1513 gpu: nvidia fan: 35%
Processes: 428 Uptime: 31m wakeups: 3 Memory: 31.28 GiB
used: 20.43 GiB (65.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2019
pm: pacman pkgs: 2009 libs: 513 tools: octopi,pamac,paru pm: flatpak
pkgs: 10 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.26
System install date:     2023-04-03
Last full system update: 2023-04-06 ↻
  1. There are three days since install, not one week.
  2. Restart your system.
  3. No problem on my two KDE DE'S.
That's strange, this system has been up for almost six months. Also had been rebooted many times these last days and rebooting didn't solved the problem.
Are you able to link the moment things started misbehaving with some sort of event that happened pretty much at the same time or just prior?
Not really, one week ago more or less, but the system has been updated often since.
This is the update log I managed to get
[2023-04-06T21:57:08+0200] [ALPM] upgraded rubberband (3.1.2-1 -> 3.2.1-1)
[2023-04-06T21:57:08+0200] [ALPM] upgraded python-humanfriendly (10.0-3 -> 10.0-4)
[2023-04-06T21:57:08+0200] [ALPM] upgraded protonup-qt (2.7.7-2 -> 2.8.0-1)
[2023-04-06T21:57:08+0200] [ALPM] upgraded wayland (1.21.0-2 -> 1.22.0-1)
[2023-04-06T21:57:08+0200] [ALPM] upgraded linux-cachyos-bore-headers (6.2.8-1 -> 6.2.9-1)
[2023-04-06T21:57:07+0200] [ALPM] upgraded linux-cachyos-bore (6.2.8-1 -> 6.2.9-1)
[2023-04-06T21:57:06+0200] [ALPM] upgraded garuda-migrations (2.2.0-1 -> 2.3.0-1)
[2023-04-06T21:57:06+0200] [ALPM] upgraded dxvk-mingw-git (2.1.r53.g3ce3209e-1 -> 2.1.r55.gd9a6b40a-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded xf86-input-wacom (1.1.0-1 -> 1.2.0-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-emulators-full (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-user (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-xtensa (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-tricore (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-sparc (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-sparc-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-sh4 (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-s390x (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-s390x-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-rx (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-riscv (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-riscv-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-ppc (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-ppc-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-or1k (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-nios2 (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-mips (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-microblaze (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-microblaze-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-m68k (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-loongarch64 (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-hppa (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-hppa-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-cris (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-avr (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-arm (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-arm-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-alpha (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-alpha-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-aarch64 (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-desktop (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-virtiofsd (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-vhost-user-gpu (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-spice-app (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-sdl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-gtk (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-egl-headless (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-dbus (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-curses (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-tools (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-x86 (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-system-x86-firmware (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-pr-helper (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-img (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-usb-smartcard (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-usb-redirect (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-usb-host (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-s390x-virtio-gpu-ccw (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-vga (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-virtio-gpu (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-hw-display-qxl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-chardev-spice (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-block-ssh (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-block-nfs (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-block-dmg (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-block-curl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-spice (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-spice-core (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-ui-opengl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-sdl (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-pa (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-oss (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-jack (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-dbus (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-audio-alsa (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded qemu-common (7.2.0-5 -> 7.2.1-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded luxtorpeda-git (62.0.0.r385.50c4181-1 -> 62.0.0.r387.a95a262-1)
[2023-04-06T08:32:12+0200] [ALPM] upgraded hplip (1:3.22.10-3 -> 1:3.23.3-1)
[2023-04-05T21:31:09+0200] [ALPM] reinstalled linux-zen-headers (6.2.9.zen1-1)
[2023-04-05T21:31:08+0200] [ALPM] reinstalled linux-zen (6.2.9.zen1-1)
[2023-04-05T20:43:30+0200] [ALPM] upgraded hwdata (0.368-1 -> 0.369-1)
[2023-04-05T18:20:44+0200] [ALPM] upgraded systemd-sysvcompat (253.2-2 -> 253.3-1)
[2023-04-05T18:20:43+0200] [ALPM] upgraded systemd (253.2-2 -> 253.3-1)
[2023-04-05T18:20:43+0200] [ALPM] upgraded plymouth-git (22.02.122.r170.ge8e19371-1 -> 22.02.122.r170.ge8e19371-2)
[2023-04-05T18:20:43+0200] [ALPM] warning: /etc/plymouth/plymouthd.conf installed as /etc/plymouth/plymouthd.conf.pacnew
[2023-04-05T18:20:43+0200] [ALPM] upgraded fzf (0.38.0-1 -> 0.39.0-1)
[2023-04-05T18:20:43+0200] [ALPM] upgraded dxvk-mingw-git (2.1.r52.gf212cc8f-1 -> 2.1.r53.g3ce3209e-1)
[2023-04-05T18:20:43+0200] [ALPM] upgraded lib32-systemd (253.2-1 -> 253.3-1)
[2023-04-05T18:20:43+0200] [ALPM] upgraded systemd-libs (253.2-2 -> 253.3-1)
[2023-04-05T13:21:20+0200] [ALPM-SCRIPTLET]    version, installed according to upstream instructions, feel free to report it through
[2023-04-05T13:21:20+0200] [ALPM] upgraded proton-ge-custom (2:GE.Proton7.53-1 -> 2:GE.Proton7.54-1)
[2023-04-05T13:21:14+0200] [ALPM] upgraded man-pages (6.03-1 -> 6.04-1)
[2023-04-05T13:21:13+0200] [ALPM] upgraded chromium (111.0.5563.146-1 -> 112.0.5615.49-1)
[2023-04-05T13:21:12+0200] [ALPM] upgraded xf86-input-libinput (1.2.1-1 -> 1.3.0-1)
[2023-04-04T21:33:16+0200] [ALPM] upgraded mkinitcpio-systemd-tool (37-2 -> 37-3)
[2023-04-04T21:33:16+0200] [ALPM] upgraded libatomic_ops (7.6.14-1 -> 7.8.0-1)
[2023-04-04T21:33:16+0200] [ALPM] upgraded heroic-games-launcher-bin (2.6.2-1 -> 2.7.0-1)
[2023-04-04T21:33:16+0200] [ALPM] upgraded dxvk-mingw-git (2.1.r51.g30691904-1 -> 2.1.r52.gf212cc8f-1)
[2023-04-04T21:33:16+0200] [ALPM] upgraded corectrl (1.3.4-1 -> 1.3.5-1)
[2023-04-04T21:33:16+0200] [ALPM] upgraded libnghttp2 (1.52.0-1 -> 1.52.0-2)
[2023-04-04T13:33:22+0200] [ALPM] upgraded systemd-sysvcompat (253.2-1 -> 253.2-2)
[2023-04-04T13:33:22+0200] [ALPM] upgraded systemd (253.2-1 -> 253.2-2)
[2023-04-04T13:33:22+0200] [ALPM] upgraded systemd-libs (253.2-1 -> 253.2-2)
[2023-04-04T13:33:21+0200] [ALPM] upgraded coreutils (9.2-2 -> 9.2-3)
[2023-04-04T13:33:21+0200] [ALPM] upgraded adobe-source-code-pro-fonts (2.038ro+1.058it+1.018var-1 -> 2.040u+1.060i+1.024vf-1)
[2023-04-04T09:16:01+0200] [ALPM] upgraded ufw (0.36.1-2 -> 0.36.1-3)
[2023-04-04T09:16:01+0200] [ALPM] upgraded mangohud (0.6.8+134+g80d394c-1 -> 0.6.8+140+g1b3f8b2-1)
[2023-04-04T09:16:01+0200] [ALPM] upgraded libvirt-python (1:9.1.0-1 -> 1:9.2.0-1)
[2023-04-04T09:16:01+0200] [ALPM] upgraded libvirt (1:9.1.0-1 -> 1:9.2.0-1)
[2023-04-04T09:16:01+0200] [ALPM] upgraded lib32-mesa (23.0.1-1 -> 23.0.1-2)
[2023-04-04T09:16:01+0200] [ALPM] upgraded mesa (23.0.1-1 -> 23.0.1-2)
[2023-04-04T09:16:01+0200] [ALPM] upgraded lib32-mangohud (0.6.8+134+g80d394c-1 -> 0.6.8+140+g1b3f8b2-1)
[2023-04-04T09:16:01+0200] [ALPM] upgraded mangohud-common (0.6.8+134+g80d394c-1 -> 0.6.8+140+g1b3f8b2-1)
[2023-04-03T20:51:55+0200] [ALPM] reinstalled woeusb (5.2.4-1.1)
[2023-04-03T20:50:24+0200] [ALPM] upgraded archisteamfarm-bin (5.4.3.2-1 -> 5.4.4.5-1)
[2023-04-03T20:50:15+0200] [ALPM] installed woeusb (5.2.4-1.1)
[2023-04-03T20:50:15+0200] [ALPM] installed wimlib (1.13.6-2)
[2023-04-03T15:57:08+0200] [ALPM] upgraded ufw (0.36.1-1 -> 0.36.1-2)
Maybe you could delete your cache in ~/.cache.
Not a bad idea to backup the folder somewhere else just in case, but it's normally safe to delete its content, especially when some weird things are happening like you suffer right now.
Don't delete the folder though, delete what's inside.
Then reboot.
A cleaner way, to me, would be to logoff your session, switch to another TTY (CTRL-ALT-F2, say) in terminal mode and do the removal from there, after backing up if you can. Then reboot.
I did this
sudo mv ~/.cache  ~/.cacheBCK
and rebooted, problem persists. Probably it's just some package on one of the latest update and maybe it will solve with another upgrade.
I switched back to latte, was working fine and I changed it since the announcement but would suffice until this solves itself.
EDIT: thanks everyone for the help, I'm closing the thread.
As requested.
