This doesn't happen everytime, but it's annoying nevertheless whenever it does - Adjusting the volume crashes KDE and gets me back to SDDM login screen.
If specifics are required : I adjust the volume by holding the keyboard media keys or the the macros on my mouse. The media key is actually Fn+ F12
for vol up and Fn+F11
for vol down (yeah it's a mac friendly kind of keyboard) . I have this keyboard connected via bluetooth.
Is this a known issue? Or is it possible to log this crash?
╰─λ inxi -Faz
Kernel: 5.15.11-arch2-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p"
acpi.dyndbg="file drivers/acpi/x86/s2idle.c +p"
BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=edc8611c-d94e-4567-85f8-02b07c91fda3 rw rootflags=subvol=@
quiet
cryptdevice=UUID=98382a7e-5fd2-4dca-b6e6-6aca242b8ece:luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
root=/dev/mapper/luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece splash
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401II.219 date: 12/30/2020
ID-1: BAT0 charge: 61.0 Wh (82.4%) condition: 74.0/76.0 Wh (97.4%)
status: Not charging
Device-1: hid-dc:2c:26:05:66:0e-battery model: Keychron K2 serial: N/A
charge: N/A status: Discharging
Device-2: hidpp_battery_0
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
Info: model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2149 high: 3336 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1654 2: 1722
3: 1773 4: 1531 5: 1693 6: 1593 7: 3336 8: 2691 9: 2277 10: 2198 11: 2661
12: 2670 bogomips: 71895
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-A-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.11-arch2-g14-1 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 6-2.4:4 chip-ID: 0bda:8153 class-ID: 0000
IF: enp4s0f4u2u4 state: up speed: 10 Mbps duplex: full mac: <filter>
bus-ID: 5-4:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 157.39 GiB (16.5%)
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 28.9 C scheme: GPT
used: 157.39 GiB (16.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
ID-1: swap-1 type: zram size: 15.11 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): cpu: 2500
Processes: 382 Uptime: 47m wakeups: 7 Memory: 15.12 GiB
used: 3.4 GiB (22.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1466 lib: 360 Shell: fish
v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
