Hi, I'm using the d460n1zed edition. I wanna try a tiling window manager called LeftWM
but I noticed that all the KDE autostarts (e.g. latte-dock) also get launched when I logged into that WM. I've tried disabling sddm.service
and start the WM directly from xinit using startx
but no luck, latte was still launched. I really wonder why.
I haven't messed with any settings of this sort of KDE autostarts (only added yakuake
). And my .xinitrc
is super clean, I just copied /etc/X11/xinit/xinitrc
and added this line at the end:
exec dbus-launch leftwm
So here's my question:
- How to prevent launching KDE autostarts when logging into another DE/WM? I'd like to know both the display manager way and xinit way.
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5ae03a95-719f-48d8-98d9-01c8f7f156e1 rw rootflags=subvol=@
nouveau.modeset=0 rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: ASUSTeK product: ROG Strix G531GU_S5DU v: 1.0
Mobo: ASUSTeK model: G531GU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G531GU.306 date: 09/24/2019
ID-1: BAT0 charge: 9.6 Wh (59.3%) condition: 16.2/66.0 Wh (24.5%)
volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 846 high: 900 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 876 3: 900 4: 900
5: 801 6: 800 7: 800 8: 800 9: 881 10: 800 11: 900 12: 900
bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 144 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 942.7 GiB used: 521.65 GiB (55.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C
temp: 25.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
ID-1: / raw-size: 250.72 GiB size: 250.72 GiB (100.00%)
used: 49.57 GiB (19.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 29.1 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 250.72 GiB size: 250.72 GiB (100.00%)
ID-4: /var/log raw-size: 250.72 GiB size: 250.72 GiB (100.00%)
ID-5: /var/tmp raw-size: 250.72 GiB size: 250.72 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 308 Uptime: 22m wakeups: 1 Memory: 15.48 GiB
used: 3.24 GiB (21.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1854 lib: 448 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-18
Last full system update: 2022-02-17
Is partially upgraded: Yes
