Everything was okey, then i shut off my computer and disconnected the cables (Mouse, keyboard, wland stick, monitor (hdmi, displayport) etc, to clean it. After it i tarted my PC and i noticed my taskbar configuration was gone and the Wallpaper was the standart again.. Then i started my usual programs (discord, vpn, browser) and in every program i was suddenly logged out here in this forum too, i suddenly wasnt logged in anymore. When i tried rebooting into a snapshot, i was greeted with this error message: "Configuration file /var/lib/sddm/.config/sddm-greeterrc not writable"
And my Keyring was reseted too. I was asked to create a key from that KDE wallet thing.
inxi -Faz:
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1e7af015-8415-4c71-aa0e-ab7b3f43faee rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: B.40
date: 11/07/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3645 high: 3812 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3603 2: 3598
3: 3594 4: 3600 5: 3601 6: 3605 7: 3603 8: 3812 9: 3769 10: 3599 11: 3586
12: 3779 bogomips: 91200
vendor: Tul driver: amdgpu v: kernel bus-ID: 2b:00.0 chip-ID: 1002:731f
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: HDMI-A-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.42.0
5.15.11-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 2b:00.1 chip-ID: 1002:ab38 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4 chip-ID: 1022:1487
Device-3: C-Media CM108 Audio Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 0d8c:013c
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8811AU 802.11a/b/g/n/ac WLAN Adapter type: USB
driver: rtl88XXau bus-ID: 3-4:4 chip-ID: 0bda:a811 class-ID: 0000
IF: wlp45s0f3u4 state: up mac: <filter>
Local Storage: total: 3.18 TiB used: 732.22 GiB (22.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 97.47 GiB (20.9%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.63 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 62.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1500
Processes: 389 Uptime: 15m wakeups: 0 Memory: 15.63 GiB
used: 3.22 GiB (20.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2260 lib: 448 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.11
