KDE and Openbox issue
Hello Garuda users.
 ╰─λ garuda-inxi
  Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=613626c9-9148-4cac-b1ca-b0c19a9b41c8 rw rootflags=subvol=@
  Desktop: Openbox v: 3.6.1 info: tint2 vt: 1 dm: SDDM Distro: Garuda Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
  Mobo: HP model: 87B2 v: 31.23 serial: <superuser required> UEFI: AMI
    v: F.25 date: 08/18/2021
  ID-1: BAT0 charge: 45.1 Wh (100.0%) condition: 45.1/45.1 Wh (100.0%)
    volts: 12.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: full cycles: 405
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
    L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1488 high: 2017 min/max: 1400/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2017 2: 1424
    3: 1543 4: 1570 5: 1509 6: 1397 7: 1419 8: 1394 9: 1397 10: 1397 11: 1397
    12: 1396 bogomips: 71867
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
    vendor: Hewlett-Packard driver: nvidia v: 515.43.04
    alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
    empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
  Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
    bus-ID: 3-3:2 chip-ID: 0408:5365 class-ID: 0e02
    compositor: Picom v: git-7e568 driver: X: loaded: modesetting,nvidia
  Monitor-1: eDP-1 model: Najing CEC Panda 0x0058 built: 2019
    res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.9-zen1-1-zen)
    v: 4.6 Mesa 22.0.4 direct render: Yes
  Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
    snd_pci_acp6x, snd_sof_amd_renoir
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
  Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
    address: <filter>
  Local Storage: total: 476.94 GiB used: 11.82 GiB (2.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: HPS0
    temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 226.68 GiB size: 226.68 GiB (100.00%)
    used: 11.79 GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 26.5 MiB (27.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 226.68 GiB size: 226.68 GiB (100.00%)
  ID-4: /var/log raw-size: 226.68 GiB size: 226.68 GiB (100.00%)
  ID-5: /var/tmp raw-size: 226.68 GiB size: 226.68 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.06 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 301 Uptime: 22m wakeups: 1 Memory: 15.06 GiB
  used: 2.35 GiB (15.6%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 12.1.0 Packages: pacman: 1462 lib: 337 Shell: Bash v: 5.1.16
  running-in: urxvt inxi: 3.3.16
Garuda (2.6.3-2):
  System install date:     2022-05-21
  Last full system update: 2022-05-22
I recently made a fresh install of Garuda KDE Dragonized on a new laptop, on launching a kde session everything seems to work fine and all applications work as intended but on using a openbox session kde based applications fail to open or work properly. I made sure everything was updated and additional kde components were installed.
Some some issues that are happening :
  • Applications likeBtrfs assistant does not launch and on launching through terminal it says application must be run as root, for some apps i can use sudo then application name to launch it but some applications cannot be launched like this.
  • KDE settings do not seem to work properly as none of the settings options even work.
  • Discover fails to display installed apps and KDE partition manager fails to load the Drive information.
Hopefully i can use openbox window manager with KDE as i really need to use some of the kde applications.
I hope someone can help you, but I am sorry to point out that changing the Window Manager is such an invasive action that it actually makes the system not officially supportable.
If you search for “openbox” in the forum you will also find old requests about it. Even the request was often to create an Openbox Edition, which says a lot about the complexity of the whole thing, in my opinion.
Anyway, I wish you good luck, maybe someone is using openbox in Garuda and/or will be able to help you.
PS: You see, e.g. inxi doesn’t even recognize your system as KDE anymore:
And your compositor is now picom:
Well i think there was a post of making Kde and Openbox work together on the Arch wiki but it is long gone now, i will wait for a bit more to see if others have an answer, TNE might be able to give some help hopefully.
If you are using a plain window manager session than the services that would normally run when KDE starts won’t be running.
You can start those services manually or add them to the openbox startup, or if you’re just trying to replace KWin with openbox then do that instead.
curious - if using kde that uses kwin, whats the desire to use openbox instead ('cause it doesn't work with lots of things)? If its to use openbox, then lxqt works fine with it (although garuda lxqt also uses kwin by default, but openbox can replace it as the wm, but the "jazz" goes (hot corners and the like, etc because openbox has no compositing effects).
How should i do that properly, could you please write the steps or provide a link to an article. And Thank you!
filo-02-sgs
What you are attempting to do is not supported by the distro precisely for the reasons you have encountered. These types of setups often create complex problems that are not easy to diagnose/correct.
If you insist on going down this road be sure to install to two different user accounts. Also be sure to specify up front on all future forum support requests exactly what you have done if you wish to try to get help with a non-standard Garuda install.
Basically, you're on your own if you choose to deviate substantially from the standard Garuda install.
