Not sure what is going on, removed these 99-corsair* files as OpenLinkHub app developer and I have resolved issue with Corsair devices.
These files have been removed from the udev/rules.d folder, but for some reason it still shows in Journalctl as warning/error flags after restarting udev daemon, and rebooting PC.
Dec 20 10:04:53 PHOENIXATE systemd-udevd[449]: /etc/udev/rules.d/99-corsair-0c2a.rules:1 Unknown user 'openlinkhub', ignoring.
Dec 20 10:04:53 PHOENIXATE systemd-udevd[449]: /etc/udev/rules.d/99-corsair-0c32.rules:1 Unknown user 'openlinkhub', ignoring.
Dec 20 10:04:53 PHOENIXATE systemd-udevd[449]: /etc/udev/rules.d/99-corsair-0c39.rules:1 Unknown user 'openlinkhub', ignoring.
Dec 20 10:04:53 PHOENIXATE systemd-udevd[449]: /etc/udev/rules.d/99-corsair-1b7c.rules:1 Unknown user 'openlinkhub', ignoring.
Dec 20 10:04:53 PHOENIXATE systemd-udevd[449]: /etc/udev/rules.d/99-corsair-1b7f.rules:1 Unknown user 'openlinkhub', ignoring.
Kernel: 6.12.5-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=0811b3c2-4fae-4301-8cc8-aee6104f5c03 rw rootflags=subvol=@
quiet resume=UUID=b1789870-3e88-4397-87ba-cf22537a4adc loglevel=3
amdgpu.ppfeaturemask=0xffffffff splash ibt=off
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5021 date: 09/29/2024
Device-1: ps-controller-battery-d0:bc:c1:fb:46:48 model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3593 min/max: 550/5084 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3593 2: 3593 3: 3593
4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
13: 3593 14: 3593 15: 3593 16: 3593 17: 3593 18: 3593 19: 3593 20: 3593
21: 3593 22: 3593 23: 3593 24: 3593 25: 3593 26: 3593 27: 3593 28: 3593
29: 3593 30: 3593 31: 3593 32: 3593 bogomips: 217291
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:3
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
navi31 LLVM 18.1.8 DRM 3.59 6.12.5-arch1-1-znver3) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 16 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
bus-ID: 0a:00.1 chip-ID: 1002:ab30 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-2.4:4 chip-ID: 054c:0ce6 class-ID: 0300
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.12.5-arch1-1-znver3 status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0032
Local Storage: total: 2.75 TiB used: 460.26 GiB (16.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 460.23 GiB (25.2%)
used: 31.7 MiB (10.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 460.23 GiB (25.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.5 C mobo: 43.0 C gpu: amdgpu temp: 51.0 C
mem: 60.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1023 fan-3: 0 fan-4: 0 fan-5: 3417
fan-6: 1942 fan-7: 0 gpu: amdgpu fan: 571
Memory: total: 32 GiB available: 31.25 GiB used: 6.01 GiB (19.2%)
Processes: 584 Power: uptime: 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1858 libs: 487 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-11-27
Last full system update: 2024-12-19
