Java applications not outputting audio
Hey! New to Garuda, been on Linux for about a year and a half. I’m having an issue with java applications not outputting audio correctly. I play runescape, and using 2 different java based clients (HDOS and Runelite), I get no audio out to my system. I have Pipewire, ALSA and JACK installed, as I do music, ALSA gives me high quality audio and good latency when needed, otherwise I wouldn’t have it. Using Qjackctl’s built in audio graph I don’t see Java present at all while the applications are open, and on my previous install they would show up there. I’ve done some searching around, but this seems like a moderately specific issue and I’m not sure where to go from here. I tried uninstalling Pipewire and installing Pulse Audio, but Rani showed that pacman was having a confliction and wouldn’t complete the execution, so I just reinstalled Pipewire. Any help would be greatly appreciated.
Kernel: 6.14.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=56e3fd53-f92b-4141-a479-2e241f5e021a rw rootflags=subvol=@
quiet rd.luks.uuid=fccf5494-1112-403b-991a-7b39bba5a7aa loglevel=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Desktop System: Gigabyte product: B650 GAMING X AX V2 v: N/A
Mobo: Gigabyte model: B650 GAMING X AX V2 v: x.x
Megatrends LLC. v: F31 date: 08/14/2024
ID-1: hidpp_battery_0 charge: 63% condition: N/A volts: 3.9 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3592 min/max: 545/5575 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3592 2: 3592 3: 3592
4: 3592 5: 3592 6: 3592 7: 3592 8: 3592 9: 3592 10: 3592 11: 3592 12: 3592
13: 3592 14: 3592 15: 3592 16: 3592 bogomips: 143728
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: ZOTAC driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2786 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
empty: Writeback-1 bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 34.0 C
Monitor-1: DP-2 model: MSI MAG301CR2 built: 2021 res: mode: 2560x1080
hz: 200 scale: 100% (1) dpi: 93 gamma: 1.2 size: 690x291mm (27.17x11.46")
diag: 762mm (30") modes: max: 2560x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 12 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4070 driver: nvidia v: 570.144 device-ID: 10de:2786
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
v: 25.0.5-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib,wayland
device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits)
driver: mesa llvmpipe v: 25.0.5-arch1.1 (LLVM 19.1.7)
Device-1: NVIDIA AD104 High Definition Audio vendor: ZOTAC
speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.3:5
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
API: ALSA v: k6.14.5-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: AzureWave
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 13d3:3586
Local Storage: total: 4.32 TiB used: 1.08 TiB (25.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Silicon Power
model: SPCC Solid State Disk size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 61.3
ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: Micron X8 SSD
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
serial: <filter> scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 42.62 GiB (2.3%)
fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-fccf5494-1112-403b-991a-7b39bba5a7aa
used: 768 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 42.62 GiB (2.3%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
ID-1: swap-1 type: zram size: 30.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: 31.5 C gpu: amdgpu temp: 35.0 C
Memory: total: 32 GiB note: est. available: 30.46 GiB used: 4.77 GiB (15.7%)
Processes: 424 Power: uptime: 50m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.11 GiB services: org_kde_powerdevil,
Packages: 1745 pm: pacman pkgs: 1736 libs: 452 tools: octopi,paru
pm: flatpak pkgs: 9 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date:     2025-05-08
Last full system update: 2025-05-10
You could try installing ffmpeg-compat-55 and pulseaudio-alsa.
Source: Reddit - Java Sound Does not Work with Other Applications Running
If that doesn’t help, which Java are you running exactly?
Apologies for the late reply. I was running JRE 24.0.1-1 from pacman, but I swapped to jre21-openjdk. I didn’t notice a change in doing this, but one of the comments on the reddit post you replied with (the one with the HEINOUS name lmfao) mentioned that runelite was “rawdogging” ALSA. I had an issue in the past where valheim would automatically default to my integrated HD audio while I had an audio interface plugged in, so to deal with that I had disabled integrated audio on my mobo. Thinking back to that I decided to try disabling them again and it seems to have fixed the issue. Runelite and HDOS now output audio correctly. I assume they were simply defaulting to the wrong device somehow, but I was confused by the fact that they weren’t showing in the Qjackctl audio graph. Thank you for the link!
