Im using Garuda since yesterday and every time I restart the system I have to configure all over again, what can I do?
Did you start from USB live ISO?
and
I install it on ssd drive from usb iso
What you do configure?
To get help be clear then possible we did not sit in front of your PC
I have 2 screens I was setting the main screen, added apps to latte bar, desktop images, steam and more and avery time i restart every thing is like if never did anything
For basic info post inxi like in
I guess Ill go back to Manjaro or maybe Ill try to reinstall Garuda and see what happens, its like using a live usb without persistance.
Are you by any chance using a Guest account that resets each time you log out?
how can I check that?
Generally by looking at the login screen. I don't know what you can see on your computer.
OK, I got it that was the problem, on the screen says guest or the account name you want to login; just make sure we choose the right one, great because so far I like the OS very much, I was playing on geforce now using chromium without any problems.
