Issues with Triple (3) monitors set up
Hello, i'm a new user and i want to join Garuda community
So my issue here is with my setup which has 3 monitors, 2 display ports and 1 HDMI
I have an AMD 6800XT (output 3 DP & 1 HDMI) and AMD CPU 3900x
I made the bootable USB with Garuda Kde gaming edition and booted from it, so it loads the kernel from the USB at the beginning and all 3 screens are in mirror mode which is fine and shows that they work properly
Next it loads Garuda and i can see that the three monitors are like extended because i can take one window and drag it along from monitor 1 to 3 properly.
Here is where the issue starts the installer won't launch with this specific monitor that i have on hdmi (monitor 3), i can install garuda with my 2 monitors or 1
After i installed garuda with 1 monitor and the system works properly i put the 2nd monitor and works fine but the 3rd monitor doesnt get image, i can see the 3rd monitor on arander
The autorandr service seems to be rearranging the primary monitor.
Even though I fixed the primary monitor via cli xrandr I cant seem to be able to enable the HDMI 3rd monitor by trying many xrandr commands
anyone has any similar issue or advice on the specifics of xrands
λ garuda-inxi
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=475458be-7a3c-4cee-8b75-a3b82bd8bc80 rw [email protected]
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4
serial: <superuser required> UEFI: American Megatrends v: P4.20
date: 08/02/2021
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3894 high: 4229 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3569 2: 3620
3: 4186 4: 4200 5: 4217 6: 4184 7: 3591 8: 2785 9: 3373 10: 4215 11: 4217
12: 3635 13: 4182 14: 3669 15: 3651 16: 3975 17: 4082 18: 4205 19: 4154
20: 3520 21: 3567 22: 4229 23: 4225 24: 4210 bogomips: 182047
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:73bf class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 5840x1920 s-dpi: 96 s-size: 1545x508mm (60.8x20.0")
s-diag: 1626mm (64")
Monitor-1: DisplayPort-0 res: 3440x1440 hz: 100 dpi: 123
size: 708x399mm (27.9x15.7") diag: 813mm (32")
Monitor-2: DisplayPort-1 res: 1920x1200 hz: 60 dpi: 94
size: 519x324mm (20.4x12.8") diag: 612mm (24.1")
Monitor-3: HDMI-A-0 res: 480x720 hz: 60
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.44.0
5.16.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: f000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: TP-Link RTL8812AU Archer T4U 802.11ac type: USB driver: N/A
bus-ID: 3-5:3 chip-ID: 2357:0101 class-ID: 0000 serial: <filter>
driver: btusb v: 0.8 bus-ID: 5-2:2 chip-ID: 0a12:0001 class-ID: e001
address: <filter>
Local Storage: total: 4.13 TiB used: 1.82 TiB (44.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM12.1 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3J scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 9300 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.9 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 476.61 GiB size: 476.61 GiB (100.00%)
used: 20.4 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
ID-3: /home raw-size: 476.61 GiB size: 476.61 GiB (100.00%)
ID-4: /var/log raw-size: 476.61 GiB size: 476.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.61 GiB size: 476.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.27 GiB used: 7 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 752
Processes: 481 Uptime: 7h 12m wakeups: 0 Memory: 31.27 GiB
used: 14.07 GiB (45.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1707 lib: 510 Shell: fish
Garuda:
System install date:     2022-01-27
Last full system update: 2022-01-27
Using TLP:               No
λ xrandr
Screen 0: minimum 320 x 200, current 5840 x 1920, maximum 16384 x 16384
DisplayPort-0 connected 3440x1440+1920+480 (normal left inverted right x axis y axis) 708mm x 399mm
3440x1440     99.99*+  59.97
2560x1440     99.99    60.07
1920x1200     99.99
1920x1080    100.00    60.00    59.94
1600x1200     99.99
1680x1050     99.94    59.95
1600x900      60.00
1280x1024     75.02    60.02
1440x900      99.99
1280x800      59.81
1152x864      75.00
1280x720      60.00    50.00    59.94
1024x768      75.03    70.07    60.00
832x624       74.55
800x600       72.19    75.00    60.32    56.25
720x576       50.00
720x480       60.00    59.94
640x480       75.00    72.81    66.67    60.00    59.94
720x400       70.08
512x288       99.98
DisplayPort-1 connected 1920x1200+0+720 (normal left inverted right x axis y axis) 519mm x 324mm
1920x1200     59.95*+
1920x1080     60.00    59.94
1600x1200     59.95
1680x1050     59.95
1400x1050     59.98
1280x1024     60.02
1440x900      59.89
1280x960      60.00
1280x800      59.81
1280x720      60.00    59.94
1024x768      60.00
800x600       60.32    56.25
720x480       60.00    59.94
640x480       60.00    59.94
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected primary 480x720+5360+0 right (normal left inverted right x axis y axis) 1600mm x 900mm
3840x2160     30.00 +  25.00    24.00    29.97    23.98
4096x2160     30.00    25.00    24.00    29.97    23.98
1920x1200     30.00
1920x1080    120.00   100.00   119.88    60.00    50.00    59.94    30.00    25.00    24.00    29.97    23.98
1600x1200     30.00
1680x1050     30.00
1280x1024     60.02
1440x900      30.00
1360x768      60.02
1280x800      30.00
1024x768      60.00
800x600       60.32
720x576       50.00
720x480       60.00*   59.94
640x480       60.00    59.94
720x400       70.08
Use ~~~ before and after the terminal text
and
:slight_smile:
Resolved , changed the HDMI cable which was new and it worked, insane
Glad you figured it out. I wouldn't exactly call it "insane" though, because I just saw a multiple monitor issue the other day the with the same solution --- which was to change out cables. :smile:
