All issues related to Garuda Linux and its assistance
Whenever my laptop wakes up from sleep , it's taking more than 2 minutes to switch on the screen and sometimes it won't switch on at all. I feel very bad about this except this everything is fine and I love garuda.my laptop specifications are given below:
HP i5-8th gen with 256gb ssd , 8gb ram .
Any help is appreciated! Thanks
Post the output of inxi -Faz
IMO the biggest factors with suspend issues are your kernel and your bios.
Test at least 4 alternate kernels and be sure your bios is up to date.
Also try different suspend states in your bios.
Be sure to post your full inxi system specs as detailed on the Garuda Wiki page on "reporting bugs".
Here's the output of inxi -Faz
System: Kernel: 5.12.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0fc89abe-9b55-4710-b3ef-36589fce7c87 rw [email protected] quiet splash
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Laptop 14-ce0xxx v: Type1ProductConfigId
Mobo: HP model: 84B9 v: 02.15 serial: <filter> UEFI: Insyde v: F.23 date: 12/25/2020
Battery: ID-1: BAT0 charge: 25.2 Wh (82.4%) condition: 30.6/30.6 Wh (100.0%) volts: 11.7
min: 11.4 model: HP Primary type: Li-ion serial: N/A status: Discharging
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache:
L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 2301 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2301 2: 3401 3: 2300
4: 2301 5: 2300 6: 3268 7: 3071 8: 2905
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
Sound Server-1: ALSA v: k5.12.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
port: 4040 bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 232.89 GiB used: 16.97 GiB (7.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 4B6Q scheme: GPT
Partition: ID-1: / raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 16.93 GiB (36.1%)
fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 38 MiB (39.6%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 16.93 GiB (36.1%)
ID-4: /var/log raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 16.93 GiB (36.1%)
ID-5: /var/tmp raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 16.93 GiB (36.1%)
ID-1: swap-1 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 979.1 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Info: Processes: 289 Uptime: 4h 20m wakeups: 2 Memory: 7.65 GiB used: 2.95 GiB (38.6%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages:
pacman: 1185 lib: 292 Shell: fish v: 3.2.2 running-in: alacritty inxi: 3.3.04
First, update your System, kernel is 5.12.12.
But System is up to date.
[email protected] in ~ took 5ms
╰─λ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
there is nothing to do
╭─[email protected] in ~ took 4s
╰─λ inxi -Faz
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Battery: ID-1: BAT0 charge: 21.2 Wh (69.3%) condition: 30.6/30.6 Wh (100.0%) volts: 11.5
L2: 6 MiB
Speed: 2053 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2053 2: 2760 3: 1828
4: 2300 5: 2301 6: 2861 7: 2301 8: 2301
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.3
direct render: Yes
Report: bt-adapter ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Drives: Local Storage: total: 232.89 GiB used: 17.41 GiB (7.5%)
Partition: ID-1: / raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 17.37 GiB (37.1%)
ID-3: /home raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 17.37 GiB (37.1%)
ID-4: /var/log raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 17.37 GiB (37.1%)
ID-5: /var/tmp raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 17.37 GiB (37.1%)
ID-1: swap-1 type: zram size: 979.1 MiB used: 130.2 MiB (13.3%) priority: 32767
ID-2: swap-2 type: zram size: 979.1 MiB used: 122.1 MiB (12.5%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 979.1 MiB used: 130.8 MiB (13.4%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 979.1 MiB used: 125.6 MiB (12.8%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 979.1 MiB used: 130.2 MiB (13.3%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 979.1 MiB used: 127.4 MiB (13.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 979.1 MiB used: 131.6 MiB (13.4%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 979.1 MiB used: 124.4 MiB (12.7%) priority: 32767
dev: /dev/zram7
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 259 Uptime: 4h 57m wakeups: 3 Memory: 7.65 GiB used: 2.89 GiB (37.8%)
These are the kernels in my system.
[email protected] in ~ took 1s
╰─λ mhwd-kernel -li
Currently running: 5.12.10-zen1-1-zen (linux-zen)
The following kernels are installed in your system:
error: No package owns /usr/lib/modules/5.12.10-zen1-1-zen/modules.builtin
local/linux-lts 5.10.45-1
local/linux-next-git 20210423.r0.ge3d35712f85a-1
local/linux-hardened 5.12.12.hardened1-1
local/linux-zen 5.12.12.zen1-1
local/linux-mainline 5.13rc6-1
You haven't rebooted your system. Always reboot on a kernel update.
Thanks I rebooted it now.
mhwd-kernel -li
Currently running: 5.12.12-zen1-1-zen (linux-zen)
I don't know if this is a KDE's bug or kernel's, but I think it is somehow related to this topic. From recently, don't know exactly from when, I get logged out automatically if lockscreen or sleep happens. Just get logged out (not shut down). But yes, even getting into SDDM screen it takes time.
(not asking for any assistance here :|)
KDE's recent big update may have reverted some of your settings to their defaults. Best to check them all.
(Not answering your non-help non-request.)
