Hello Guys, I've got into a undefined problem. It already starts with the issue I can't even say where it might come from except it appears on my last upgrade (which changes the kernel to the version 6.0.2).
I've no YouTube playback - mostly I can see one frame or just the thumbnail of the video.
I've got no audio, whether on any video file with different video players (like VLC, MPV refuses to play videos all together, I literally need to click frame per frame to see something).
The upgrade ran without any error, which doesn't help me either. And due to research in the net I found umpties different reasons which I can't even remotely relate to. B/c my rig ran before the upgrade without any issues. (Stuff like: HW issues, codec issues, drivers issues).
The AMD driver doesn't change et all, and it worked before the upgrade as well, and very well.
Trying another upgrade after the initial upgrade leaves me with "nothing to do". And I don't have any messages about "Partially upgraded system"-warnings or anything. According to my Garuda everything runs fine. No issues with the compositor, no issues with the animations, none. Except, starting a youtube video or any other video file. Even all my games are rendering properly but there is no audio either. Even early access unstable stuff, runs fine, just without any audio.
I've checked if anything is muted, for the case of, although it doesn't make sense either since I've got decoding issues due to issues with the audio. I'm using my on board audio card, so the audio isn't related to my GPU anyways.
I suspect it has something to do with the kernel upgrade but. I couldn't find anything related to that, but a ton of other issues I don't have, as it is usual with major upgrades.
There is my garuda-inxi of course:
╰─λ garuda-inx
root=UUID=de43fccd-7f1e-439e-9eca-59d05e719941 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.F0
date: 12/16/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3943 high: 4669 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 4665 6: 3800 7: 3737 8: 3729 9: 4661 10: 3721 11: 3800
12: 3720 13: 4669 14: 3800 15: 3800 16: 3800 bogomips: 121593
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2f:00.0 chip-ID: 1002:73bf
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2:3 chip-ID: 0c45:6536
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: Asus VS248
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: Asus VS248
OpenGL: renderer: AMD Radeon RX 6800 XT (navi21 LLVM 14.0.6 DRM 3.48
6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-2:3 pcie: gen: 4 chip-ID: 0c45:6536 class-ID: 0102 speed: 16 GT/s
lanes: 16 serial: <filter> bus-ID: 2f:00.1 chip-ID: 1002:ab28
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microdia USB Live camera type: USB
Device-4: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-2:2 chip-ID: 0d8c:0135 class-ID: 0300
Sound Server-1: PulseAudio v: 16.1 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 724.45 GiB (77.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P4CR311
temp: 48.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 724.45 GiB
(77.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 724.45
GiB (77.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 724.45
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 724.45
ID-1: swap-1 type: zram size: 62.72 GiB used: 1.5 MiB (0.0%)
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Processes: 372 Uptime: 11m wakeups: 0 Memory: 62.72 GiB used: 6.64 GiB
(10.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2240
libs: 590 tools: octopi,pamac,paru Shell: fish v: 3.5.1 running-in: konsole
inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-08-09
Last full system update: 2022-10-18
And the lspci:
[🔍] × lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5405
20:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
21:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
21:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
21:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
21:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
21:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
26:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
27:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
2a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
2a:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
2a:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
2b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
2c:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
2d:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev c1)
2e:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch
2f:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] (rev c1)
2f:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
30:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
31:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
31:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
31:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
All the sound server are running, nothing is muted, hence I suspect a decoding issue, or even a driver issue of some sort. Maybe based on the new kernel? Mp3's ain't doing nothing in any player either.
I hope there is a solution except from rolling back
Thanks in advance,
Bruce
