Issues with Jackbox Party Pack 11 after switching Proton Compatibility
I was able to play the game initially without much issues and today, it’s given me issues. Below is the message I get when I try to run it:
TJPP11_Vulkan failed due to the following problems:
[S_API] SteamAPI_Init(): Loaded '/home/kojack/.local/share/Steam/linux64/steamclient.so' OK.
Setting breakpad minidump AppID = 3364070
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198143489383 [API loaded no]
Unknown positional value ""
Fossilize INFO: Overriding serialization path: "/home/kojack/.local/share/Steam/steamapps/shadercache/3364070/fozpipelinesv6/steamapprun_pipeline_cache".
You may find more information in
TJPP11-log.txt
Here’s my specs from the inxi:
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=927c8be1-9103-4d8d-b710-aad24afb9c0b rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QR_GA503QR
Mobo: ASUSTeK model: GA503QR v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: GA503QR.416 date: 08/11/2023
ID-1: BAT0 charge: 62.7 Wh (100%) condition: 62.7/90 Wh (69.7%) volts: 15.86
min: 15.86 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A charging:
status: not charging control: start: N/A end: 100% cycles: N/A
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500012
Speed (MHz): avg: 2918 min/max: 423/4683 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2918 2: 2918 3: 2918
4: 2918 5: 2918 6: 2918 7: 2918 8: 2918 9: 2918 10: 2918 11: 2918 12: 2918
13: 2918 14: 2918 15: 2918 16: 2918 bogomips: 105400
ssse3 svm
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 580.105.08 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:249d
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 07:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 88.0 C
alternate: fbdev,nouveau,nv,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x152a built: 2020 res:
mode: 2560x1440 hz: 165 scale: 125% (1.25) to: 2048x1152 dpi: 189 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
renoir ACO DRM 3.64 6.17.9-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 Laptop GPU driver: nvidia v: 580.105.08
device-ID: 10de:249d surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl,nvidia-smi wl: wayland-info
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 8087:0029
Local Storage: total: 2.79 TiB used: 233.04 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 model: PCIe SSD size: 1.86 TiB
tech: SSD serial: <filter> fw-rev: EDFM60.0 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 48.9 C
used: 233.04 GiB (24.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 22.87 GiB used: 12 KiB (0.0%) priority: 100
System Temperatures: cpu: 96.9 C mobo: N/A gpu: amdgpu temp: 88.0 C
Fan Speeds (rpm): cpu: 4900
Memory: total: 24 GiB note: est. available: 22.87 GiB used: 7.87 GiB (34.4%)
Processes: 452 Power: uptime: 1h 23m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 9.02 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2273 libs: 530 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.3
default: fish v: 4.2.1 running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date:     2025-11-23
Last full system update: 2025-11-30 ↻
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-dkms garuda-hardware-profile-standard
25/26 checks run in 1.54 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
- Nvidia drivers are installed, but no hardware profile is active (fix available)
Any help is appreciated, though if I need to hop to another distro or go back to Fedora, I will do so. Or hell, I could even just go to Vanilla Arch, if needed.
Update: I have solved this issue by forcing it to run the stable proton build (10.0.03), and then forcing it to choose to run just Jackbox Party Pack 11 over the megapicker. A bit of toying with the settings!
