Issues with games and Bluetooth headset
Preformatted textSystem:
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bafd18ce-cd6b-4899-9832-93c36cfb3955 rw rootflags=subvol=@
Mobo: ASUSTeK model: PRIME X670-P WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0823
date: 11/21/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4727 high: 5438 min/max: 3000/5453 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 5238 2: 5438
3: 4700 4: 3888 5: 4507 6: 5434 7: 3287 8: 4700 9: 4700 10: 4700 11: 4700
12: 5438 bogomips: 112588
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:7480 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-2
bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 42.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: D40fM-K09 built: 2022
res: 1920x1080 hz: 60 dpi: 69 gamma: 1.2 size: 708x398mm (27.87x15.67")
diag: 1016mm (40") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Graphics
(gfx1102 LLVM 16.0.6 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: AzureWave driver: rtw89_8852be v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 0b:00.0
chip-ID: 10ec:b852 class-ID: 0280
IF: wlp11s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.82 TiB used: 39.4 GiB (2.1%)
fw-rev: 2B2QEXM7 temp: 51.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 39.4 GiB (2.1%)
used: 39.4 GiB (2.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.5 C mobo: N/A
GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 40.0 C mem: 54.0 C
fan: 1 watts: 9.00
Processes: 351 Uptime: 7m wakeups: 2 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 3.57 GiB (11.7%) Init: systemd v: 254
pm: pacman pkgs: 1391 libs: 388
tools: gnome-software,octopi,pamac,paru,trizen Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-09-07
Last full system update: 2023-09-08
Welcome @Popcorn. When you have a chance please explain what the issue you are having is, and describe what you have done so far to troubleshoot.
Looks like you have both PipeWire and PulseAudio active; that could be at least part of the problem. Have you tried just with Pipewire? (Pipewire has its own way to run Pulse through pipewire-pulse)
You might be able to fix it by using Garuda Assistant, and going to the System Components tab. Remove the PulseAudio support and PipeWire support (since the PipeWire installation looks only to be partially there) then hit apply. Then Click the PipeWire support to check the box this time, and hit apply.
Hopefully that will set the components properly. If it still does not work after a restart, could you give us a new garuda-inxi output after all that?
Alright, It’s working now, thanks! I’m still having issues with games crashing, so if you know how to fix it or know someone who does I would greatly appreciate it!
