Hello, I am relatively new to garuda and today, after restarting my laptop, my command terminal suddenly switched from fish to bash and the dragonized theme is disabled. I have no idea what could have caused this, as I did not do a system update or really much of anything.
So far I have tried reappliying the GTK theme to no avail.
Does anyone know what happened and how i can fix it?
Thanks a lot
Hi, welcome
Open garuda-assistant and restore what you need.
Hi IronicOwl,
Konsole may have switched back to default which it sometimes does if it bombs out and the Garuda reset mentioned above doesn't always work. Try this:
Open Konsole
Click Settings > Configure Console (CTRL+Shift+,)
Choose Profiles
Click on Garuda and then set as default.
That should get you back
Which part dos not work always?
And welcome too
Hi SGS,
I had exactly the same thing as described after I forcibly closed Konsole, using Assistant to reset the Fish config didn't work for me, still opened as standard Bash prompt.
SF
λ sudo cat /etc/skel/.local/share/konsole/Garuda.profile
[Appearance]
ColorScheme=Sweetified
Font=FiraCode Nerd Font Mono,12,-1,5,50,0,0,0,0,0
UseFontLineChararacters=true
[Cursor Options]
CursorShape=2
CustomCursorColor=255,0,0
UseCustomCursorColor=true
[General]
Command=/usr/bin/fish
Name=Garuda
Parent=FALLBACK/
TerminalColumns=110
The supplied default config is still correct. The same for the fish config. Please try to copy it in place manually:
cp /etc/skel/.local/share/konsole/Garuda.profile ~/.local/share/konsole/Garuda.profile
cp /etc/skel/. config/konsolerc ~/.config/konsolerc
cp /etc/skel/.config/fish/config.fish ~/.config/fish/config.fish
Thank you very much, this did it for me. And thanks to all other answers as well!
I thought that too but honestly so long as he's working I don't think it matters
