Whenever after using the application if I close it , the application closes successfully but the application image will get struck on the screen . At first I thought this is due to over ram usage but when I checked the ram usage ,more than 70 percent of the ram is free.My system is up to date and everytime it get struck I have to logout and login again. This is not good as the work iam doing will stop .Attaching screenshot for reference.
NOTE: Struck in the sense just the wallpaper of my os is replaced by the app image and everything is working fine like launching applications and everything. Some may get it like Struck means os got frozen.
output of inxi -Fza
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0fc89abe-9b55-4710-b3ef-36589fce7c87
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Laptop 14-ce0xxx v: Type1ProductConfigId
Mobo: HP model: 84B9 v: 02.15 serial: <filter> UEFI: Insyde v: F.23 date: 12/25/2020
Battery: ID-1: BAT0 charge: 27.7 Wh (100.0%) condition: 27.7/27.7 Wh (100.0%) volts: 12.8 min: 11.4
model: HP Primary type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3401 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3401 2: 3401 3: 3401 4: 3401
5: 3400 6: 3400 7: 3400 8: 3400
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-3:4
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: 4040
bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:5
chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 232.89 GiB used: 25.2 GiB (10.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 4B6Q scheme: GPT
Partition: ID-1: / raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 25.17 GiB (53.7%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 38 MiB (39.6%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 25.17 GiB (53.7%) fs: btrfs
ID-4: /var/log raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 25.17 GiB (53.7%) fs: btrfs
ID-5: /var/tmp raw-size: 46.85 GiB size: 46.85 GiB (100.00%) used: 25.17 GiB (53.7%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 1.27 GiB (16.7%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Info: Processes: 304 Uptime: 2d 22h 56m wakeups: 11 Memory: 7.65 GiB used: 5.01 GiB (65.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1269 lib: 327 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.05
