Issues booting a Virtual Machine with Single GPU Passthrough
I recently managed to get a virtual machine working with Single GPU Passthrough but I've been having issues with getting it started. I've been able to get into it, but very unreliably. Most of the time it either kicks me back to the login screen (Which is normal when the VM quits gracefully) or I just lose all display output and my system seems to hang, not responding to Ctrl+Alt+Del, requiring a hard power off.
Last time I managed to get the VM running, earlier today, was when I SSH'd into my host from a separate machine and ran sudo virsh start to see if I'd get any console output on a failiure. I didn't have the time to try it again to see if it would fail with errors.
I'm confident the start hook script works as the VM will go into windows and work perfectly fine when it does want to work and the release script will reliably rebind the GPU and set me back to the host. Nor do I get any errors when I run the scripts in an SSH session.
I've tried looking at the var log but I can't make heads or tails of it, so I'll share that here for extra info.
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e9fb4e39-76f0-470b-b069-4298b6b21895 rw [email protected]
nvidia-drm.modeset=1 amd_iommu=on iommu=pt video=efifb:off quiet splash
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5602
date: 07/14/2020
Device-1: ps-controller-battery-4c:b9:9b:8e:d3:95 model: N/A serial: N/A
charge: N/A status: charging
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3637 high: 3883 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3883 4: 3697 5: 3595 6: 3654 7: 3622 8: 3600 9: 3600 10: 3600 11: 3600
12: 3600 bogomips: 86241
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Palit Microsystems
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1,HDMI-A-1
empty: DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2484 class-ID: 0300
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-right
model: Samsung LC27G7xT serial: <filter> built: 2020 res: 2560x1440
dpi: 65024 gamma: 1.2 size: 1x1mm (0.04x0.04") diag: 686mm (27")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-l
model: Acer KG271 C serial: <filter> built: 2018 res: 1920x1080 dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Palit Microsystems
driver: snd_hda_intel v: kernel bus-ID: 3-1:2 pcie: chip-ID: 1852:7022
class-ID: 0102 gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: GYROCOM C&C Fiio E10 type: USB
Device-4: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid bus-ID: 3-4:4 chip-ID: 054c:0ce6
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-3: Sony DualSense wireless controller (PS5) type: USB
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:3
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 6.82 TiB used: 1.26 TiB (18.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: Portable
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0712 scheme: MBR
ID-1: / raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
used: 326.36 GiB (35.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.80%)
used: 152.7 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-4: /var/log raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 1.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 49.2 C mobo: N/A gpu: nvidia temp: 32 C
Processes: 439 Uptime: 25m wakeups: 2 Memory: 31.28 GiB
used: 5.69 GiB (18.2%) Init: systemd v: 252 default: graphical
pkgs: 1961 libs: 494 tools: octopi,pamac,paru Shell: fish v: 3.5.1
running-in: yakuake inxi: 3.3.23
Garuda (2.6.9-1):
System install date:     2022-03-03
Last full system update: 2022-11-29 ↻
Failed units:            plymouth-deactivate.service plymouth-start.service
Here is the output of the VM log file.
2022-11-29 17:33:46.224+0000: starting up libvirt version: 8.9.0, qemu version: 7.1.0, kernel: 6.0.10-zen2-1-zen, hostname: BaulMachine2
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin \
HOME=/var/lib/libvirt/qemu/domain-1-win10-2 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-win10-2/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-win10-2/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-win10-2/.config \
/usr/bin/qemu-system-x86_64 \
-name guest=win10-2,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-1-win10-2/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/edk2-ovmf/x64/OVMF_CODE.secboot.4m.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/win10-2_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-q35-7.1,usb=off,vmport=off,smm=on,dump-guest-core=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-accel kvm \
-cpu host,migratable=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff \
-global driver=cfi.pflash01,property=secure,value=on \
-m 16384 \
-object '{"qom-type":"memory-backend-memfd","id":"pc.ram","share":true,"x-use-canonical-path-for-ramblock-id":false,"size":17179869184}' \
-overcommit mem-lock=off \
-smp 6,sockets=1,dies=1,cores=6,threads=1 \
-uuid 2add6cf0-b813-44c7-b482-66e1d2e54dd3 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=30,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-shutdown \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot menu=off,strict=on \
-device '{"driver":"pcie-root-port","port":16,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x2"}' \
-device '{"driver":"pcie-root-port","port":17,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x2.0x1"}' \
-device '{"driver":"pcie-root-port","port":18,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x2.0x2"}' \
-device '{"driver":"pcie-root-port","port":19,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x2.0x3"}' \
-device '{"driver":"pcie-root-port","port":20,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x2.0x4"}' \
-device '{"driver":"pcie-root-port","port":21,"chassis":6,"id":"pci.6","bus":"pcie.0","addr":"0x2.0x5"}' \
-device '{"driver":"pcie-root-port","port":22,"chassis":7,"id":"pci.7","bus":"pcie.0","addr":"0x2.0x6"}' \
-device '{"driver":"pcie-root-port","port":23,"chassis":8,"id":"pci.8","bus":"pcie.0","addr":"0x2.0x7"}' \
-device '{"driver":"pcie-root-port","port":24,"chassis":9,"id":"pci.9","bus":"pcie.0","multifunction":true,"addr":"0x3"}' \
-device '{"driver":"pcie-root-port","port":25,"chassis":10,"id":"pci.10","bus":"pcie.0","addr":"0x3.0x1"}' \
-device '{"driver":"pcie-root-port","port":26,"chassis":11,"id":"pci.11","bus":"pcie.0","addr":"0x3.0x2"}' \
-device '{"driver":"pcie-root-port","port":27,"chassis":12,"id":"pci.12","bus":"pcie.0","addr":"0x3.0x3"}' \
-device '{"driver":"pcie-root-port","port":28,"chassis":13,"id":"pci.13","bus":"pcie.0","addr":"0x3.0x4"}' \
-device '{"driver":"pcie-root-port","port":29,"chassis":14,"id":"pci.14","bus":"pcie.0","addr":"0x3.0x5"}' \
-device '{"driver":"pcie-root-port","port":30,"chassis":15,"id":"pci.15","bus":"pcie.0","addr":"0x3.0x6"}' \
-device '{"driver":"pcie-pci-bridge","id":"pci.16","bus":"pci.1","addr":"0x0"}' \
-device '{"driver":"qemu-xhci","p2":15,"p3":15,"id":"usb","bus":"pci.2","addr":"0x0"}' \
-device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.3","addr":"0x0"}' \
-blockdev '{"driver":"file","filename":"/mnt/Speedy/QEMU/win10-2.qcow2","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"driver":"qcow2","file":"libvirt-1-storage","backing":null}' \
-device '{"driver":"virtio-blk-pci","bus":"pci.6","addr":"0x0","drive":"libvirt-1-format","id":"virtio-disk0","bootindex":1}' \
-netdev tap,fd=32,id=hostnet0 \
-device '{"driver":"rtl8139","netdev":"hostnet0","id":"net0","mac":"52:54:00:4d:4c:b9","bus":"pci.16","addr":"0x1"}' \
-chardev pty,id=charserial0 \
-device '{"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0}' \
-chardev spicevmc,id=charchannel0,name=vdagent \
-device '{"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"com.redhat.spice.0"}' \
-device '{"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1"}' \
-audiodev '{"id":"audio1","driver":"spice"}' \
-vnc 0.0.0.0:0,audiodev=audio1 \
-spice port=0,disable-ticketing=on,image-compression=off,seamless-migration=on \
-device '{"driver":"virtio-vga","id":"video0","max_outputs":1,"bus":"pcie.0","addr":"0x1"}' \
-device '{"driver":"ich9-intel-hda","id":"sound0","bus":"pcie.0","addr":"0x1b"}' \
-device '{"driver":"hda-duplex","id":"sound0-codec0","bus":"sound0.0","cad":0,"audiodev":"audio1"}' \
-chardev spicevmc,id=charredir0,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir0","id":"redir0","bus":"usb.0","port":"2"}' \
-chardev spicevmc,id=charredir1,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir1","id":"redir1","bus":"usb.0","port":"3"}' \
-device '{"driver":"vfio-pci","host":"0000:0a:00.0","id":"hostdev0","bus":"pci.7","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0a:00.1","id":"hostdev1","bus":"pci.8","addr":"0x0"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/001/004","id":"hostdev2","bus":"usb.0","port":"4"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/003/003","id":"hostdev3","bus":"usb.0","port":"5"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/003/002","id":"hostdev4","bus":"usb.0","port":"6"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/001/002","id":"hostdev5","bus":"usb.0","port":"7"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/003/004","id":"hostdev6","bus":"usb.0","port":"8"}' \
-device '{"driver":"virtio-balloon-pci","id":"balloon0","bus":"pci.4","addr":"0x0"}' \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2022-11-29 17:33:52.702+0000: shutting down, reason=failed
2022-11-29T17:33:52.703313Z qemu-system-x86_64: terminating on signal 15 from pid 87246 (/usr/bin/libvirtd)
