Sorry for the generic title, it's just I am getting various different kinds of issues.
fish keeps forgetting history, like every time my laptop goes to sleep. zsh and bash do remember (my default is zsh). Not even the arrow shortcuts giving me past searches on fish.
The new btrfs assistant is the only program that doesn't seem to respect system font settings. It uses the default Fira Sans I think.
This is an old one actually, but there seems to be some kind of memory leak on using any browser. RAM consumption on startup : 1.8-2GB. After using a browser and closing it, about 3.1GB. I have plenty of RAM to spare, but why use that 1GB if not needed? I am not even getting that back on reusing browser, it starts using more. Even while writing this, I am using 3.6GB RAM with just 1 tab on brave browser(600-700MB consumption), and nothing else running in background.
╰─λ inxi -Faz
Kernel: 5.15.7-arch1-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p"
acpi.dyndbg="file drivers/acpi/x86/s2idle.c +p"
BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=edc8611c-d94e-4567-85f8-02b07c91fda3 rw [email protected]
quiet
cryptdevice=UUID=98382a7e-5fd2-4dca-b6e6-6aca242b8ece:luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
root=/dev/mapper/luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece splash
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401II.219 date: 12/30/2020
ID-1: BAT0 charge: 55.4 Wh (74.9%) condition: 74.0/76.0 Wh (97.4%)
status: Discharging
Device-1: hid-dc:2c:26:05:66:0e-battery model: Keychron K2 serial: N/A
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
charge: N/A status:
Device-2: hidpp_battery_0
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status:
Info: model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2051 high: 2420 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2185 2: 2211
3: 2220 4: 2309 5: 2420 6: 2211 7: 1820 8: 1912 9: 1822 10: 1382 11: 1800
12: 2322 bogomips: 71897
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158
size: 309x174mm (12.2x6.9") diag: 355mm (14")
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-arch1-g14-1 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 5-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 111.49 GiB (11.7%)
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 27.9 C scheme: GPT
used: 111.49 GiB (11.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
ID-1: swap-1 type: zram size: 15.11 GiB used: 668 KiB (0.0%)
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 345 Uptime: 7h 14m wakeups: 45 Memory: 15.12 GiB
used: 3.63 GiB (24.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1443 lib: 355 Shell: fish
v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.10
