Issue with Steam connectivity
Hi dear Garuda Users,
first of the garuda-inxi.
Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=7cf01614-c787-4e94-b2fe-5c99e8361719 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: GIGABYTE product: A5 K1 v: N/A
Mobo: GIGABYTE model: A5 K1 serial: <superuser required> UEFI: INSYDE
v: 1.07.FB09 date: 09/27/2021
ID-1: BAT0 charge: 42.7 Wh (100.0%) condition: 42.7/47.2 Wh (90.6%)
volts: 16.7 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3680 high: 4168 min/max: 400/4280 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3334 2: 3332 3: 3333
4: 4168 5: 4166 6: 4168 7: 3328 8: 4167 9: 3333 10: 4167 11: 3333 12: 3333
bogomips: 79059
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: CLEVO/KAPOK driver: nvidia v: 535.113.01
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 64.0 C
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04f2:b729
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08b3 built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 398mm (15.7") ratio: 16:9 modes: max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.5.8-zen1-1-zen) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 535.113.01
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: NVIDIA GA106 High Definition Audio vendor: CLEVO/KAPOK
Device-2: AMD Renoir Radeon High Definition Audio vendor: CLEVO/KAPOK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: CLEVO/KAPOK
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: CLEVO/KAPOK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8125 2.5GbE vendor: CLEVO/KAPOK driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 198.82 GiB (41.7%)
model: MZVL2512HCJQ-00B00 size: 476.94 GiB block-size: physical: 512 B
fw-rev: GXA7401Q temp: 35.9 C scheme: GPT
used: 198.81 GiB (41.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.98 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 76.1 C mobo: N/A gpu: amdgpu temp: 63.0 C
Processes: 361 Uptime: 29m wakeups: 3745 Memory: total: 16 GiB note: est.
available: 14.98 GiB used: 7.34 GiB (49.0%) Init: systemd v: 254
pm: pacman pkgs: 1558 libs: 524 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-17
Last full system update: 2023-10-24
I recently switched to Garuda Linux and I ran into a big problem. I have already checked the Arch Wiki and this forum for any people running into similar issues and either I’m blind or nobody else had this issue. Whenever I play Steam games online my Steam connections seems to disappear. To clarify only my steam online connection disappears. My Discord and any other software seems to run fine. I have never had issues with steam connectivity.
Things I already tried where rebooting several times out of desperation and reinstalling the Steam packages.
Hopefully someone knows how to fix it!
Try changing the DNS servers.
You can use the Garuda Assistant.
Thanks for your reply I’ll try that!
Hey, sorry unfortunately that didn’t work, do you have another solution I could try?
Does somebody else have a solution? It’s really annoying to play online games and just suddenly get disconnected out of nowhere
