Issue with Mesa drivers
I have a fresh installed Garuda and a new video card Intel Arc B580. I know only a few things about Mesa drivers and I have no experience for that. All drivers installed, as I can see, but some applications like Vivaldi, Spectacle and Steam keep crashing immediately after start. In fact, i see only a flash on a screen and “process terminated”
root=UUID=b652cee0-0b2f-4c68-96d3-097471b387e9 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: H610M S2H V2 DDR4 v: -CF
Mobo: Gigabyte model: H610M S2H V2 DDR4 v: x.x
Megatrends LLC. v: F26 date: 08/31/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x3A
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 800 min/max: 800/5600 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 59904
Device-1: Intel Battlemage G21 [Arc B580] vendor: Shenzhen Gunnir
Development driver: xe v: kernel arch: Xe2 process: TSMC n4 (4nm)
built: 2024+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-3
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-4 bus-ID: 03:00.0
chip-ID: 8086:e20b class-ID: 0300
compositor: kwin_wayland driver: X: loaded: intel,modesetting
alternate: fbdev,vesa dri: iris gpu: xe display-ID: 0
Monitor-1: HDMI-A-3 model: HP 24w serial: <filter> built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (BMG G21)
device-ID: 8086:e20b memory: 11.65 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 9 device: 0 type: discrete-gpu name: Intel
Graphics (BMG G21) driver: mesa intel v: 25.0.5-arch1.1
device-ID: 8086:e20b surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-2: Intel vendor: Shenzhen Gunnir Development driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 1 speed: 2.5 GT/s
bus-ID: 04:00.0 chip-ID: 8086:e2f7 class-ID: 0403
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.87 TiB used: 1.13 TiB (39.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: DGSM3001TS33T size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: V1013A0 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EARS-00Y5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 0A80 scheme: MBR
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 6313 scheme: MBR
used: 30.65 GiB (3.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.17 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 119.24 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 39.0 C mobo: 30.0 C
Memory: total: 32 GiB available: 31.17 GiB used: 4.24 GiB (13.6%)
Processes: 452 Power: uptime: 2h 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2292 libs: 593 tools: octopi,pamac,paru pm: rpm
pkgs: 0 pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 15.1.1
Shell: garuda-inxi default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date:     2025-05-18
Last full system update: 2025-05-18
hi Astro and welcome back :wink:
im not to much in it with this gpu , but you can try to update your bios too it helped me with my amd vega gpu before too.
may try another update . Did you try mesa tkg git?
