Issue with Keyrings
I'm having some issues with key rings mailspring is telling me it cannot store my password securely. make sure I have libsecret and a keyring.
I go to the garuda assistant click refresh Keyrings
and get this in Konsole
/bin/bash: line 1: pacman-key --init && pacman -Qs archlinux-keyring && pacman-key --populate archlinux & pacman -Qs chaotic-keyring && pacman-key --populate chaotic & pacman -Qs blackarch-keyring && pacman-key --populate blackarch: command not found
when I try to do it manually in terminal it tells me i need root privilege for pacman-key.
I also get an error in the assistant that I'm failing to access groups for current user
Yeah, you do need root rights for that command to work.
