Issue with Bluetooth audio setup
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0d041406-fe13-41c0-b9f2-4c294e2a1d84 rw rootflags=subvol=@
intel_iommu=on iommu=pt quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=dff8cd6b-a08c-479d-bb33-80f49a2c20cb loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: B460M-A PRO (MS-7C88) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.60
date: 11/30/2020
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3323 high: 4222 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 2900 2: 2900 3: 2900
4: 2900 5: 4138 6: 4222 7: 4158 8: 4162 9: 2900 10: 2900 11: 2900 12: 2900
bogomips: 69597
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia v: 535.86.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Screen-1: 0 s-res: 4480x1440 s-dpi: 107 s-size: 1064x342mm (41.89x13.46")
s-diag: 1118mm (44")
Monitor-1: DP-0 pos: primary,top-right res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1920x1080 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:10f9 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.2:8
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
Device-1: USB2.0-BT driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-7:15 chip-ID: 33fa:0001 class-ID: e001
Local Storage: total: 953.87 GiB used: 199.81 GiB (20.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk
model: SSDPR-PX500-01T-80 size: 953.87 GiB block-size: physical: 512 B
fw-rev: V2.1.3 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
used: 199.81 GiB (21.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /home raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-3: /var/log raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-4: /var/tmp raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Processes: 302 Uptime: 22m wakeups: 2 Memory: total: 16 GiB
available: 15.56 GiB used: 5.12 GiB (32.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1827 libs: 479 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
System install date:     2023-07-22
Last full system update: 2023-08-08 ↻
I have bought a new headset today, and i want to connect to it using Bluetooth. I have used the kde system settings for that. But I can't select them as my audio device. This are the devices that show up:
I have tried to swich to all of them but non play anything in the headphones.
Can you see if you can stream audio after giving pipewire a restart with this:
systemctl restart --user pipewire-pulse.socket pipewire.socket wireplumber.service
I don't know why but after yesterday's update my volume control gets stuck with no way to increase/decrease volume at times and this is the temporary resolution I found. I also noticed that I have a bunch of random devices in my KDE's volume systray during this time just like you that can't change the volume of my device either.
Nope, restarting pipewire does not solve the problem, even an entire system restart will do anything.
