Hello I am new using garuda. Im trying to install linux-zen kernel. I used to use arch but I am stumped on this issue. So like normal i run 'sudo update-grub' and I get all the normal text but at the end it is telling me.
Info: Separate boot partition not detected
Found snapshot: 2021-02-02 15:07:47 | timeshift-btrfs/snapshots/2021-02-02_15-07-47/@
Found snapshot: 2021-02-02 15:04:51 | timeshift-btrfs/snapshots/2021-02-02_15-04-51/@
Found snapshot: 2021-02-01 18:50:30 | timeshift-btrfs/snapshots/2021-02-01_18-50-29/@
Found snapshot: 2021-02-01 17:38:47 | timeshift-btrfs/snapshots/2021-02-01_17-38-47/@
umount: /tmp/tmp.ffpGkNgiEa: target is busy.
Can you please help. Thanks!
Welcome to the forum & Garuda
Im pretty sure that this is caused by a recent grub-btrfs update, please try downgrading this package to the previous version by
sudo downgrade grub-btrfs
and update grub again afterwards.
Thank you, I just tried this and i am getting the same result.
To be clear, after downgrade you do
sudo update-grub
[🔴] × sudo downgrade grub-btrfs
Available packages:
1) grub-btrfs 4.0.1 1 any (remote)
2) grub-btrfs 4.0.2 1 any (remote)
3) grub-btrfs 4.1 1 any (remote)
4) grub-btrfs 4.2 1 any (remote)
5) grub-btrfs 4.2.1 1 any (remote)
6) grub-btrfs 4.3 1 any (remote)
7) grub-btrfs 4.4 1 any (remote)
8) grub-btrfs 4.5 1 any (remote)
9) grub-btrfs 4.6 1 any (remote)
10) grub-btrfs 4.7 1 any (remote)
11) grub-btrfs 4.7.1 1 any (remote)
12) grub-btrfs 4.7.2 1 any (remote)
13) grub-btrfs 4.7.2 1 any (local)
+ 14) grub-btrfs 4.8.1 1 any (remote)
+ 15) grub-btrfs 4.8.1 1 any (local)
select a package by number: 13
loading packages...
warning: downgrading package grub-btrfs (4.8.1-1 => 4.7.2-1)
λ sudo update-grub
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found linux image: /boot/vmlinuz-linux-xanmod-cacule
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-xanmod-cacule.img
Found fallback initrd image(s) in /boot: initramfs-linux-xanmod-cacule-fallback.img
Detecting snapshots ...
Found snapshot: 2021-02-02 14:00:01 | timeshift-btrfs/snapshots/2021-02-02_14-00-01/@
Found snapshot: 2021-01-31 17:00:01 | timeshift-btrfs/snapshots/2021-01-31_17-00-01/@
Found snapshot: 2021-01-30 17:00:01 | timeshift-btrfs/snapshots/2021-01-30_17-00-01/@
Found snapshot: 2021-01-29 16:57:50 | timeshift-btrfs/snapshots/2021-01-29_16-57-50/@
Found 4 snapshot(s)
done
still not working here is my output downgrading grub
Subscribing to this, I have that issue as well, as others.
Will try a downgrade as well.
Well, there was a message about the process failing but that was just before the actual downgrade happened?
did you manually update-grub afterwards?
i just typed sudo update-grub
yes i typed enter lmao
I confirm this is working.
I downgraded from 4.8.1.1 to 4.7.2.1 and both the Fish alias grubup="sudo update-grub"
and sudo update-grub now work.
╭─frank at Garuda in ⌁
╰─λ sudo update-grub
Found linux image: /boot/vmlinuz-linux-tkg-bmq
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-tkg-bmq.img
Found fallback initrd image(s) in /boot: initramfs-linux-tkg-bmq-fallback.img
Found snapshot: 2021-02-02 09:52:34 | @snapshots/ad-hoc/@.nvidia
Found snapshot: 2021-01-27 20:28:05 | @snapshots/ad-hoc/@.b4_bkp_2021-01-27-20H28
Found snapshot: 2021-01-24 20:42:25 | @snapshots/ad-hoc/@.locale_2021-01-24_20H41
Found snapshot: 2021-01-16 15:52:05 | @.bkp
Found 4 snapshot(s)
done
╰─λ grubup
Found 4 snapshot(s)
done
I have advised Antynea on git-hub. Maybe the problem is a conflicting Arch/Garuda package, I don't know, but at least he will be looking on his side too.
Don't mind the wrongful title of the above link, it was regarding a different issue and I have asked if we should split into a new issue.
Here is the new real issue at grub-btrfs github:
Well it seems this is Garuda related.
Antynea says he can reproduce the issue on Garuda distros, but not on Manjaro...
@dr460nf1r3 @SGS , sorry to ping you like this, what should be the next step?
I think Antynea would need someone from Garuda to continue the discussion...
Nice to ping me, but I am here only the painter and "girl" for everything except programming of really important things.
Girl... ok I'll remember that!! lolll
It's true you do paint marvelous images, though. I'm using one of yours as my background. But that's off topic here.
That statement is a little premature, as Garuda uses different kernels than Manjaro, so this could possibly be a kernel issue. Did you test the linux
kernel that Manjaro is using by default.
It's somewhere in performance-tweaks.
I installed it and could then reproduce the problem.
After i removed it, disabled the services and restarted, I could not reproduce.
Not yet sure which part it is tho.
I'm using linux-zen
I think it's prelockd-git.
Edit: either prelockd-git or precached-git.
After I disabled prelockd and restart I can still reproduce.
After I disable precached and restart I cannot reproduce.
Edit1: With performance-tweaks installed memavaild disabled and masked (some other problem I haven't got to yet) and precached-git disabled/masked and after a restart I cannot reproduce.
prelockd is enabled and running.
Stil on linux-zen.
Its definitely precached
