I believe the problem is that my monitors do not turn back on or don’t display the graphics, since my keyboard does light up, meaning that it does wake up from sleep.
I have checked my BIOS settings and everything seems to be set correctly.
I tried adding mem_sleep_default=s2idle , but that also didn’t help much (it made things worse).
LANGUAGE = “LANGUAGE”,
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = (unset),
LC_COLLATE = (unset),
LC_TIME = (unset),
LC_MESSAGES = (unset),
LC_MONETARY = “LC_MONETARY”,
LC_ADDRESS = (unset),
LC_IDENTIFICATION = (unset),
LC_MEASUREMENT = “LC_MEASUREMENT”,
LC_PAPER = (unset),
LC_TELEPHONE = “LC_TELEPHONE”,
LC_NAME = (unset),
LANG = “en_GB.UTF-8”
perl: warning: Falling back to a fallback locale (“en_GB.UTF-8”).
Kernel: 6.17.3-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=802f85f7-7c2c-4f8e-b049-c67c4202c3eb rw rootflags=subvol=@
nouveau.backlist=1 loglevel=3 mem_sleep_default=s2idle
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Laptop System: Dell product: Dell G15 5520 v: N/A
serial: Chassis: type: 10 serial:
Mobo: Dell model: 05J7DY v: A07 serial: part-nu: 0B56
uuid: UEFI: Dell v: 1.35.0 date: 08/07/2025
ID-1: BAT0 charge: 33.5 Wh (90.7%) condition: 36.9/84.3 Wh (43.8%)
health: good temp: 28.4 C volts: 12.07 min: 11.4 model: BYD DELL M59JH28
made: 2022-08-11 type: Li-poly serial: charging: status: charging
control: start: 50% end: 90% type: adaptive
avail: adaptive,custom,fast,standard,trickle cycles: N/A
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x437
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 473 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 473 2: 473 3: 473 4: 473
5: 473 6: 473 7: 473 8: 473 9: 473 10: 473 11: 473 12: 473 13: 473 14: 473
15: 473 16: 473 17: 473 18: 473 19: 473 20: 473 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 580.95.05 alternate: nouveau,nvidia_drm
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 ports:
active: none empty: HDMI-A-1,eDP-2 bus-ID: 0000:01:00.0 chip-ID: 10de:2560
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 0c45:6738
class-ID: 0e02
display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x06e2 built: 2021 res: mode: 1920x1080
hz: 165 scale: 120% (1.2) to: 1600x900 dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a6 memory: 14.94 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 11 device: 0 type: integrated-gpu
name: Intel Iris Xe Graphics (ADL GT2) driver: mesa intel v: 25.2.4-arch1.2
device-ID: 8086:46a6 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 580.95.05
device-ID: 10de:2560 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.2 (LLVM
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Google Nexus/Pixel Device (MIDI) driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 18d1:4ee8
class-ID: 0103 serial:
API: ALSA v: k6.17.3-zen2-1-zen status: kernel-api
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
Device-2: Realtek Killer E2600 GbE vendor: Dell driver: r8169 v: kernel
port: 3000 bus-ID: 0000:3a:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp58s0 state: down mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.82 TiB used: 183.84 GiB (9.9%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 731100WD temp: 51.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 183.81 GiB (9.9%)
used: 29.6 MiB (9.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 183.81 GiB (9.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C mobo: 54.0 C
Fan Speeds (rpm): cpu: 2139 fan-1: 2111 fan-2: 2424
Memory: total: 16 GiB note: est. available: 15.3 GiB used: 4.91 GiB (32.1%)
Processes: 449 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
image: 6.01 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: 1806 pm: pacman pkgs: 1766 libs: 447 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 40 Compilers: clang: 20.1.8
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
Garuda (2.11.1-1):
System install date: 2024-07-18
Garuda release: 240428
Last full system update: 2025-11-02 ↻
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
cat /proc/acpi/wakeup | grep enabled
PEG1 S4 *enabled pci:0000:00:01.0
XHCI S0 *enabled pci:0000:00:14.0
RP07 S4 *enabled pci:0000:00:1c.0
TXHC S4 *enabled pci:0000:00:0d.0
TDM0 S4 *enabled pci:0000:00:0d.2
TRP0 S4 *enabled pci:0000:00:07.0
AWAC S4 *enabled platform:ACPI000E:00
LID0 S3 *enabled platform:PNP0C0D:00
PBTN S3 *enabled platform:PNP0C0C:00
grep . /sys/bus/platform/devices/i8042/serio0/power/wakeup
enabled
