the error i get when trying to update is;
error: failed retrieving file 'blackarch.db' from mirrors.fossho.st : HTTP/2 stream 0 was not closed cleanly: PROTOCOL_ERROR (err 1)
garuda-inxi output
Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=2fe9abcf-9467-43a8-9a27-708da0c5febf rw rootflags=subvol=@
resume=UUID=abfb7f86-9005-4ac4-af24-25b62ef9cdd5 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: LENOVO product: 20L9CTO1WW v: ThinkPad T580
Mobo: LENOVO model: 20L9CTO1WW v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N27ET42W (1.28 )
date: 05/13/2021
ID-1: BAT0 charge: 22.4 Wh (79.4%) condition: 28.2/32.0 Wh (88.2%)
volts: 16.3 min: 15.3 model: SMP 00UR891 type: Li-poly serial: <filter>
status: not charging cycles: 162
ID-2: BAT1 charge: 15.3 Wh (67.1%) condition: 22.8/71.1 Wh (32.0%)
volts: 11.8 min: 11.2 model: LGC 01AV492 type: Li-ion serial: <filter>
status: charging cycles: 274
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4000 scaling: driver: intel_pstate
8: 800 bogomips: 31999
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nvidia
v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d10 class-ID: 0302
Device-3: Acer Integrated IR Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 5986:1141 class-ID: 0e02 serial: <filter>
Device-4: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 5986:2113 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: BOE Display 0x06d7 built: 2016 res: 3840x2160
hz: 60 dpi: 283 gamma: 1.2 size: 345x194mm (13.58x7.64")
diag: 396mm (15.6") ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 22.1.3 direct render: Yes
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 953.87 GiB used: 40.83 GiB (4.3%)
model: MZVLB1T0HALR-000L7 size: 953.87 GiB block-size: physical: 512 B
rev: 5L2QEXA7 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 919.37 GiB size: 919.37 GiB (100.00%)
used: 40.83 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 919.37 GiB size: 919.37 GiB (100.00%)
ID-4: /var/log raw-size: 919.37 GiB size: 919.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.37 GiB size: 919.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
Message: No sensor data found. Is lm-sensors configured?
Processes: 277 Uptime: 14m wakeups: 5 Memory: 31.09 GiB
used: 4.63 GiB (14.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2102
lib: 400 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
error: blackarch: signature from "Levon 'noptrix' Kayan (BlackArch Developer) <noptrix@nullsecurity.net>" is invalid
Garuda (2.6.5-1):
System install date: 2022-03-06
Last full system update: 2022-07-14
