Issue report: i needed to chroot and reinstall GRUB after my system automatically shut itself down
hey folks!
no huge issue to fix as i have already remedied my immediate problem, i just wanted to report a serious glitch that i had today after my machine turned itself off after the 45 mins i have it set to.
i had no issues starting up earlier this morning after a manual shutdown last night and i have done nothing to the system since a system update on the 21st, i cleaned out some old snapshots afterwards and that’s it.
i was reading the news online and left to take my dogs for a walk and when i returned my rig was powered off as expected but when i started it back up i had a total grub failure.
i had to chroot from a liveOS and reinstall grub as i had an ‘unknown filesystem’ error and ended up in grub recovery mode.
i have no clue as to why this happened and i have never encountered this before and feel that i should report the incident to the team due to the significance of the issue.
iirc i was running only firedragon and protonvpn’s GUI app at the time of the automatic shutdown.
lemme know if there is anything like log files or something else i can provide for you folks to analyze.
thanks all! =-)
garuda-inxi funstuff
  Kernel: 6.1.59-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=63f3c83e-5747-44de-974f-c89d4101bd95 rw rootflags=subvol=@
    resume=UUID=c0d4fb48-27bb-458a-9d32-db4bea9d7420 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Desktop Mobo: MSI model: Z77A-GD55 (MS-7751) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.11
    date: 11/20/2013
  Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3266 high: 3783 min/max: 1600/3900 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 3127 2: 2766 3: 3676
    4: 3425 5: 3566 6: 2973 7: 2813 8: 3783 bogomips: 56022
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
    process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:731f class-ID: 0300
  Monitor-1: DP-3 mapped: DisplayPort-2 model: Asus VX238 serial: <filter>
    built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
    size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5600 XT (navi10 LLVM
    16.0.6 DRM 3.49 6.1.59-1-lts) device-ID: 1002:731f memory: 5.86 GiB
    unified: no
  API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5600 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    vendor: Micro-Star MSI 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
  API: ALSA v: k6.1.59-1-lts status: kernel-api with: aoss
  Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
    v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 2.91 TiB used: 395.96 GiB (13.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SH103S3120G
    tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SH103S3120G
  ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400S37480G
  ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
    model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: MBR
  ID-1: / raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
    used: 19.53 GiB (49.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 71.04 GiB size: 71.04 GiB (100.00%)
    used: 22.68 GiB (31.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
  ID-5: /var/tmp raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
  ID-1: swap-1 type: zram size: 23.42 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
    mem: 36.0 C
  Processes: 329 Uptime: 4m wakeups: 0 Memory: total: 24 GiB
  available: 23.42 GiB used: 3.03 GiB (13.0%) Init: systemd v: 254
  pm: pacman pkgs: 2007 libs: 563 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
  System install date:     2023-04-12
  Last full system update: 2023-10-22
  Total system updates:    40
  --> Updates per week:    1
Power blackout?
If no one else here complains, it seems to have hit only you.
Looks like my casual server is still a little OC.
  Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=cfe93033-525c-4209-bf64-584214ef666e rw rootflags=subvol=@ rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 ibt=off
  Console: pty pts/0 DM: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: P8Z77-V DELUXE v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2104 date: 08/13/2013
  Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge gen: core 3 level: v2
    built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2658 high: 4224 min/max: 1600/4100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1600 2: 4224 3: 1600 4: 1600 5: 4224 6: 2200 7: 1600 8: 4223
    bogomips: 57684
:smiley:
/shrugs
it got fixed lol
i put this base rig together in 2011 to last me a decade and i’m happy with it.
haven’t found a game i can’t play on it yet =-)
