Issue installing GPU drivers
Attempting to reinstall drivers in hardware configuration resulting in failure, marked as uninstalled, yet still installed resulting in confliction when attempting to install nvidia drivers from hardware configuration
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 clocksource: tsc
avail: hpet,acpi_pm
root=UUID=4aac3ebc-374d-4e7c-9d1b-629c23010d90 rw
rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A
info: frameworks v: 6.0.0 wm: kwin_wayland vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B550 AORUS ELITE
v: N/A serial: <superuser required>
Mobo: Gigabyte model: B550 AORUS ELITE v: x.x
BIOS: American Megatrends v: F10 date: 09/18/2020
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16
smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3599 high: 3600 min/max: 2200/4426
boost: enabled scaling: driver: acpi-cpufreq
governor: performance cores: 1: 3600 2: 3600 3: 3600
4: 3600 5: 3600 6: 3600 7: 3593 8: 3600 9: 3600
10: 3600 11: 3600 12: 3600 13: 3600 14: 3600 15: 3600
16: 3600 bogomips: 114990
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 sse4a ssse3 svm
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER]
vendor: eVga.com. driver: N/A alternate: nouveau
non-free: 545.xx+ status: current (as of 2024-02;
EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1e84
Display: wayland server: X.org v: 1.21.1.11
with: Xwayland v: 23.2.4 compositor: kwin_wayland driver:
X: loaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 640x480 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: swrast wayland:
drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM
17.0.6 256 bits) device-ID: ffffffff:ffffffff
memory: 30.55 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: cpu
name: llvmpipe (LLVM 17.0.6 256 bits)
driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM 17.0.6)
Device-1: NVIDIA TU104 HD Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 8 GT/s bus-ID: 0a:00.1 chip-ID: 10de:10f8
Device-2: AMD Starship/Matisse HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-3: HP HyperX SoloCast
driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-3:3 chip-ID: 03f0:078b class-ID: 0300
Device-4: Razer USA BlackShark V2 Pro
bus-ID: 1-9:7 chip-ID: 1532:0528 class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api
with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with:
1: pipewire-pulse status: active 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8125
IF: eno1 state: up speed: 1000 Mbps duplex: full
mac: <filter>
Local Storage: total: 1.36 TiB used: 50.73 GiB (3.6%)
SMART Message: Unable to run smartctl. Root privileges
required.
model: SSD 980 PRO 500GB size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7
temp: 45.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
model: SSD 970 EVO Plus 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD 860 EVO 500GB size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 50.73 GiB (10.9%) fs: btrfs dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /home raw-size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 50.73 GiB (10.9%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /var/log raw-size: 465.76 GiB
ID-4: /var/tmp raw-size: 465.76 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 31.28 GiB
used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16
System Temperatures: cpu: 62.2 C mobo: 43.0 C
Memory: total: 32 GiB available: 31.28 GiB
used: 4.51 GiB (14.4%)
Processes: 327 Power: uptime: 18m
states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.5 GiB
services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical
Packages: 2096 pm: dpkg pkgs: 1
tools: apt,apt-get,gnome-software pm: pacman pkgs: 2095
libs: 568 tools: octopi,paru Compilers: clang: 17.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date:     2024-03-15
Last full system update: 2024-03-24
There may be an issue of some kind with this tool at the moment. Instead, install the drivers according to the instruction on the ArchWiki page: NVIDIA - ArchWiki
For the Maxwell (NV110/GMXXX) series and newer, install the nvidia package (for use with the linux kernel) or nvidia-lts package (for use with the linux-lts kernel) or nvidia-dkms package (for all other kernels).
In your case the installation will look like this:
sudo pacman -S nvidia-dkms
