Try other kernel, LTS and post your garuda-inxi and stop begging for help, please, not pls.
i want to post my system specification garuda-inxi
but at system reboot it got stuck on the home screen so how i can use the konsole?
You can post your garuda-inxi
from a live boot disk environment.
ok i m posting , give me some time
If you experience the same issue in a live disk that was working fine before, then you may have developed a hardware problem.
No no
In live environment it is working fine
My guess would be an nvidia driver update has created this issue. That is only speculation of course.
So this is probably issue from nvidia team
Is it?
Yes, but only on Notebooks. But we wait for the garuda-inxi
One minute
Sry for delay
I m doing boot
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
Mobo: HP model: 88DD v: 96.33 serial: <superuser required> UEFI: AMI
v: F.23 date: 10/20/2022
ID-1: BAT0 charge: 9.2 Wh (22.3%) condition: 41.3/41.3 Wh (100.0%)
volts: 10.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1205 high: 1267 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1267
3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 bogomips: 79053
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: N/A
alternate: nouveau non-free: 515.xx+ status: current (as of 2022-10)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 49.0 C
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:0035 class-ID: fe01
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0058 built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: RENOIR (renoir LLVM 14.0.6 DRM 3.48 6.0.2-zen1-1-zen)
v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie:
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 505.81 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: PC711 HFS512GDE9X073N size: 476.94 GiB block-size: physical: 512 B
rev: HPS0 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Sony model: Storage Media
size: 28.88 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: GPT
ID-1: swap-1 type: zram size: 7.11 GiB used: 1.12 GiB (15.7%)
System Temperatures: cpu: 80.2 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 271 Uptime: 3m wakeups: 1 Memory: 7.11 GiB used: 3.25 GiB
(45.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1220 libs: 308
Garuda (2.6.8-1):
System install date: 2023-01-24
Last full system update: 2023-01-24 ↻
Failed units: mhwd-live.service
sry i don't know to write it in well format
You put the text between ``` or ~~~
Use LTS kernel, solved problem in other thread.
can you tell me how to change the kernel or any thread where this discussion had opened
Pls learn to search to solve a "problem"
sudo pacman -S kernel-lts kernel-lts-headers
In grub use advanced for new kernel.
ok
actually i am new to linux
thats why
but no prblm thanks again for your time and help
