Issue Audio after update
Hello,
I'm a new user and I have little knowledge about linux. I installed dragonizer for gaming. After the update, the system stopped detecting the audio device.
root=UUID=cc22d647-3194-4ef0-a5a2-100f23a41fb9 rw rootflags=subvol=@
resume=UUID=8c3b8ab7-43c6-4652-9179-55b64d03eeea loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Predator PH317-54 v: V1.06
Mobo: CML model: Vellfire_CMS v: V1.06 serial: <superuser required>
UEFI: Insyde v: 1.06 date: 11/25/2020
ID-1: BAT0 charge: 43.4 Wh (100.0%) condition: 43.4/58.8 Wh (73.9%)
volts: 16.6 min: 15.4 model: SMP KT00407009 AP18E7M type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2600 min/max: 800/5000 scaling: driver: intel_pstate
governor: performance cores: 1: 2600 2: 2600 3: 2600 4: 2600 5: 2600 6: 2600
7: 2600 8: 2600 9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: eDP-1 empty: DP-2, DP-3, DP-4, HDMI-A-2, HDMI-A-3
bus-ID: 0000:00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nouveau v: kernel
alternate: nvidia_drm,nvidia non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 ports: active: none
empty: DP-1,HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:1f15
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:a061
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x175c built: 2018 res: 1920x1080
hz: 144 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
bus-ID: 0000:00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f9
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:06f0
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: alx v: kernel port: 3000
bus-ID: 0000:06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Hardware-1: Intel Comet Lake PCH-H RAID driver: intel_nvme_remap v: N/A
port: 5060 bus-ID: 0000:00:17.0 chip-ID: 8086:06d7 rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 18.62 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B tech: SSD serial: <filter> fw-rev: 11101100 temp: 46.9 C
ID-1: / raw-size: 442.34 GiB size: 442.34 GiB (100.00%)
used: 18.62 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 442.34 GiB size: 442.34 GiB (100.00%)
ID-4: /var/log raw-size: 442.34 GiB size: 442.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.34 GiB size: 442.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.3 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C pch: 42.0 C mobo: N/A gpu: nouveau
temp: 36.0 C
Processes: 316 Uptime: 31m wakeups: 2 Memory: total: 32 GiB
available: 31.19 GiB used: 3.37 GiB (10.8%) Init: systemd v: 254
pm: pacman pkgs: 1821 libs: 522 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-21
Last full system update: 2023-08-21 ↻
Pls help
Have you tried to see if the issue persists after a reboot? The symbol means there is a pending reboot. (Not to mention rebooting after the first update is even more important, as there is newer kernel to boot into after the reboot)
We, i reebot system. My system newer get up. Black screen. Loadin linux linux-zen
Loading initial ramdisk
Double check your BIOS settings to confirm your device’s SATA controller is set to AHCI mode.
Seems to be effecting people after a recent update:
