Issue Accessing Application with linux-zen
Hi everyone,
I’m having trouble accessing an application using linux-zen. The application runs without any issues when I use regular Linux, but I can’t get it to work with linux-zen. I really don’t understand what’s causing this problem. Can anyone help me figure this out?
Thanks in advance!
Post template:
Issue still unresolved? Then:
  • ONE issue per topic.
garuda-inxi output :
    root=UUID=a0893c50-757c-43ff-aa03-20c1aa2765ce rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Laptop System: HP product: HP Laptop 14s-dk1xxx v: N/A
  Mobo: HP model: 879E v: 84.54 serial: <superuser required>
    part-nu: 2Z295PA#AR6 uuid: <superuser required> UEFI: AMI v: F.70
    date: 07/18/2023
  ID-1: BAT0 charge: 22.5 Wh (100.0%) condition: 22.5/22.5 Wh (100.0%)
    volts: 12.7 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: full
  Info: model: AMD Athlon Silver 3050U with Radeon Graphics bits: 64 type: MCP
    arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108109
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
    desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 2783 high: 3090 min/max: 1400/2300 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2476 2: 3090
    bogomips: 9183
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 90.0 C
  Device-2: Chicony HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b67f
  Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
    drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
    raven2 LLVM 17.0.6 DRM 3.57 6.9.7-zen1-1-zen) device-ID: 1002:15d8
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RAVEN2) driver: mesa radv v: 24.1.2-arch1.1
    device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
    bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
  API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
  Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 0bda:b00a
  Local Storage: total: 295.78 GiB used: 215.92 GiB (73.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: PC SA530
    SDASN8Y-256G-1006 size: 238.47 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1006
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
    size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 79.77 GiB size: 79.77 GiB (100.00%)
    used: 65.99 GiB (82.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
    used: 56.5 MiB (5.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 79.77 GiB size: 79.77 GiB (100.00%)
  ID-4: /var/log raw-size: 79.77 GiB size: 79.77 GiB (100.00%)
  ID-5: /var/tmp raw-size: 79.77 GiB size: 79.77 GiB (100.00%)
  ID-1: swap-1 type: zram size: 5.7 GiB used: 761.5 MiB (13.0%)
    priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2
  System Temperatures: cpu: 90.0 C mobo: N/A gpu: amdgpu temp: 90.0 C
  Memory: total: 6 GiB note: est. available: 5.7 GiB used: 4.13 GiB (72.4%)
  Processes: 219 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.27 GiB services: org_kde_powerdevil,
  Packages: 1706 pm: dpkg pkgs: 0 pm: pacman pkgs: 1700 libs: 411
    tools: octopi,paru,yay pm: flatpak pkgs: 6 Compilers: clang: 17.0.6
    gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: code
    inxi: 3.3.35
  System install date:     2023-10-19
  Last full system update: 2024-07-03
  Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio
  Failed units:            systemd-vconsole-setup.service
 ╭─doniws@doniws in ~/Hacking/wa-spam is  v1.0.0 via  v22.3.0 via  v3.12.4 took 8s
 ╰─λ
 ╰─λ
 ╰─λ
 ╰─λ
 ╰─λ
 ╰─λ
 ╰─λ
 ╰─λ garuda-inxi
    date: 07/18/2023
    desc: 1x4 MiB
  Speed (MHz): avg: 1421 high: 1443 min/max: 1400/2300 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1443
    bogomips: 9183
    class-ID: 0300 temp: 84.0 C
  ID-1: swap-1 type: zram size: 5.7 GiB used: 1 GiB (17.6%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
  System Temperatures: cpu: 84.2 C mobo: N/A gpu: amdgpu temp: 84.0 C
  Memory: total: 6 GiB note: est. available: 5.7 GiB used: 4.1 GiB (71.9%)
  Processes: 222 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    inxi: 3.3.35
I cannot access applications via their icons, and this only happens on linux-zen. For example, when I click the Microsoft Edge icon, I get the error: “failed Unit app-microsoft\[email protected] not found.” This happens with almost all application icons. However, when I boot using regular Linux/ Linux Linux, all application icons work fine and run without issues.
Just use what works.
Weak CPUs may not be properly supported by Zen. Switch to X11 in the login window.
Further research is not worthwhile.
For newcomers:
The “linux” kernel package is the latest kernel available which is super fast & modern in itself.
Take a look at this topic, maybe it will help:
Thank you for helping me resolve the issue.
