Issue about starting on Workspace 3 instead of 1
I need some guidance as to why my system is starting on workspace 3. It's rather annoying and would much rather start on the first workspace.
I've check all my startup applications, and none of them steal the focus, and I can't seem to find any options to change the default workspace. I don't even know if that's that issue.
I'm very confused.
What is the garuda-inxi output?
I think this is what your asking for?
CPU: 8-core AMD Ryzen 7 3700X (-MT MCP-)
speed/min/max: 3605/2200/4426 MHz
Kernel: 5.19.1-zen1-1-zen x86_64 Up: 57m
Mem: 5854.0/15917.9 MiB (36.8%)
Storage: 1.85 TiB (6.5% used)
Procs: 377 Shell: fish inxi: 3.3.20
When creating a new topic in the issues and assistance forum, there is a template which you have to delete before posting that asks for your garuda-inxi output. This contains information like your hardware, and what software is running on your machine.
What desktop environment are you running, KDE?
Hello Garuda users.
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
How to search for solutions the right way | Garuda Linux wiki
  Kernel: 5.19.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f6cccf9c-8580-435e-8f33-927e3e31bb2d
    resume=UUID=2e9cba84-8fd3-4884-995e-6ac1c54716ad loglevel=3 ibt=off
  Console: pty pts/0 DM: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required> UEFI: American
    Megatrends LLC. v: F34 date: 06/10/2021
  Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3 built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache: L1: 1024 KiB desc: d-16x32
    KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 3515 high: 3595 min/max: 2200/4761 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3595 3: 3500 4: 3500 5: 3500
    6: 3500 7: 3500 8: 3500 9: 3589 10: 3500 11: 3500 12: 3548 13: 3500 14: 3500 15: 3500
    16: 3593 17: 3592 18: 3500 19: 3500 20: 3500 21: 3500 22: 3500 23: 3500 24: 3592 25: 3500
    26: 3500 27: 3500 28: 3500 29: 3500 30: 3500 31: 3500 32: 3500 bogomips: 223589
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP: always-on, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI driver: nvidia
    v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-07)
    arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1e84 class-ID: 0300
  Device-2: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-3.4.3:7 chip-ID: 046d:085c class-ID: 0102 serial: <filter>
  Device-3: Focusrite-Novation Scarlett 2i2 Camera type: USB driver: snd-usb-audio
    bus-ID: 7-2:2 chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
  Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X: loaded: nvidia
    unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia tty: 128x32
  Message: GL data unavailable in console. Try -G --display
  Device-1: YUAN High-Tech Development vendor: Corsair Memory driver: N/A bus-ID: 1-3.4.3:7 pcie:
    chip-ID: 046d:085c gen: 1 class-ID: 0102 speed: 2.5 GT/s serial: <filter> lanes: 1
    bus-ID: 06:00.0 chip-ID: 12ab:0380 class-ID: 0480
  Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.1
  Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
  Device-5: Texas Instruments ATH-G1WL type: USB driver: hid-generic,snd-usb-audio,usbhid
    bus-ID: 1-3.4.4:8 chip-ID: 0451:16ba class-ID: 0300 serial: <filter>
  Device-6: Focusrite-Novation Scarlett 2i2 Camera type: USB driver: snd-usb-audio
  Sound Server-1: ALSA v: k5.19.1-zen1-1-zen running: yes
  Sound Server-3: PipeWire v: 0.3.56 running: no
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
  Local Storage: total: 4.57 TiB used: 846.12 GiB (18.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SanDisk model: ADATA SX6000PNP size: 953.87 GiB
    rev: V9002s85 temp: 34.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WDS100T1XHE-00AFY0
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 614600WD temp: 26.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EARX-00ZUDB0 size: 1.82 TiB
    serial: <filter> rev: 0A80 scheme: GPT
  ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 369.45 GiB (41.2%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 369.45 GiB (41.2%)
  ID-4: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 369.45 GiB (41.2%)
  ID-5: /var/tmp raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 369.45 GiB (41.2%)
  ID-1: swap-1 type: zram size: 31.29 GiB used: 1.2 MiB (0.0%) priority: 100 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 34.49 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
    maj-min: 8:3
  System Temperatures: cpu: 33.5 C mobo: 28.0 C gpu: nvidia temp: 28 C
  Processes: 422 Uptime: 4h 5m wakeups: 0 Memory: 31.29 GiB used: 1.57 GiB (5.0%) Init: systemd
  v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 11 clang: 14.0.6
  Packages: pacman: 2232 lib: 555 Shell: Bash v: 5.1.16 running-in: pty pts/0 (SSH) inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2022-01-22
  Last full system update: 2022-08-17
  Failed units:            sendmail.service
To be clear, I"m not asking for someone to solve this for me. I asking for guidance on where to start poking around. Its not an issue that needs imminent attention, its just an annoying problem I've been dealing with.
root=UUID=eb1642e5-80d1-40de-9de6-c741e6927fa7 rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.C0
date: 05/18/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3597 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3599 9: 3600 10: 3600 11: 3600
12: 3557 13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115205
protection
Device-1: AMD Tonga PRO [Radeon R9 285/380] vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DVI-D-1,DVI-D-2 bus-ID: 27:00.0
chip-ID: 1002:6939 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung built: 2011
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 184mm (7.2") ratio: 16:9 modes: max: 1366x768 min: 720x400
OpenGL: renderer: AMD Radeon R9 380 Series (tonga LLVM 14.0.6 DRM 3.47
5.19.1-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Tonga HDMI Audio [Radeon R9 285/380] vendor: Micro-Star MSI
bus-ID: 27:00.1 chip-ID: 1002:aad8 class-ID: 0403
bus-ID: 29:00.4 chip-ID: 1022:1487 class-ID: 0403
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 24:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF: wlp36s0 state: down mac: <filter>
bus-ID: 1-14:3 chip-ID: 8087:07dc class-ID: e001
Device-2: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 5-3.1.3:5 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Report: ID: hci1 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.85 TiB used: 124 GiB (6.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KLEVV model: CRAS C710 M.2 NVMe
SSD 1TB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: U0204A0L
temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: TeamGroup model: TM8FP6512G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2.H.5.0
temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545050B9A300
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C64G scheme: MBR
ID-1: / raw-size: 238.46 GiB size: 238.46 GiB (100.00%) used: 123.97 GiB
(52.0%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:6
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 30.2 MiB
(5.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.46 GiB size: 238.46 GiB (100.00%) used: 123.97
GiB (52.0%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:6
ID-4: /var/log raw-size: 238.46 GiB size: 238.46 GiB (100.00%) used: 123.97
ID-5: /var/tmp raw-size: 238.46 GiB size: 238.46 GiB (100.00%) used: 123.97
ID-1: swap-1 type: zram size: 15.54 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: 36.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): fan-1: 2495 fan-2: 1170 fan-3: 689 fan-4: 883
fan-5: 914 fan-6: 876 gpu: amdgpu fan: 1284
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.25 gpu: amdgpu watts: 43.02
Processes: 366 Uptime: 1h 9m wakeups: 6 Memory: 15.54 GiB used: 5.74 GiB
(36.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1994 lib: 554
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date:     2022-05-13
Failed units:            run-media-malvazar-server.mount run-media-malvazar-serverbackup.mount
I found these two potential solutions, and had a thought about looking at your virtual desktop list in the settings. You've probably already tried the latter.
Do you have "restore session" enabled in KDE System Settings?
Okay so I worked with wmctrl before, and have it installed and working. How ever I can't seem to get a script to execute with it on startup.
I made a example.sh file, then put in:
sleep 5 && wmctrl -s 0
Linked the file in the autostart application, but nothing happen on a reboot.a
And no i don't have restore session enable. It doesn't solve the issue, and it likes to open mutable instances of applications. Which in itself becomes annoying.
Is this checked?
Current virtual desktop: :ballot_box_with_check: Remember for each activity
No it was not, and it did not fix the problem either sadly.
