Is there a way to theme btrfs assistant and snapper tools?
I want to apply a dark theme.
  Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=b6b92ddd-1165-4684-927f-b9ae66d45eff rw rootflags=subvol=@ rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 mitigations=off sysrq_always_enabled=1 ibt=off
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
  Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> UEFI: American Megatrends
    v: X540LA.303 date: 08/31/2018
  ID-1: BAT0 charge: 15.8 Wh (68.4%) condition: 23.1/33.2 Wh (69.6%) power: 14.0 W volts: 10.8
    min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: charging cycles: 727
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1995 min/max: 500/1900 scaling: driver: intel_cpufreq governor: performance
    cores: 1: 1995 2: 1995 3: 1995 4: 1995 bogomips: 15961
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell
    driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915
    display-ID: 0
  Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
    min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
    memory: 7.47 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
    (BDW GT2) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
    device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
    v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
  IF: enp2s0f2 state: down mac: <fil
ter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: no pairing: no class-ID: c010c
  Local Storage: total: 704.24 GiB used: 614.4 GiB (87.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.99 GiB (36.1%) fs: btrfs
    dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
    dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 9.8 GiB size: 9.8 GiB (100.00%) used: 5.46 GiB (55.8%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.99 GiB (36.1%) fs: btrfs
  ID-5: /var/tmp raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.99 GiB (36.1%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.65 GiB used: 384 MiB (4.9%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 54.0 C pch: 46.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 2200
  Processes: 272 Uptime: 11h 45m wakeups: 1 Memory: total: 8 GiB available: 7.65 GiB
  used: 4.16 GiB (54.4%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: 1214 pm: pacman pkgs: 1195 libs: 349 tools: pamac,paru pm: flatpak pkgs: 19
  Client: shell wrapper v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-27
  Last full system update: 2023-12-15 ↻
I wanted the same but gave up.
Apparently they both run with root level access which does not pick up the current theme.
If someone comes back with answer which allows it, that would be good.
I guess supplying the required configs in /root (likely kvantum ones) could be a workaround.
how do you do that?
One way to set it up is run sudo kvantummanager and set up your theme there.
Or you can copy over your user settings:
sudo cp ~/.config/Kvantum /root/.config
nope btrfs assistant is is still light.
though garuda boot options followed the kvantum theme
Nope what? What did you do before you got “nope”?
What is your method for launching it?
from the gnome app menu
i did : ``` sudo cp ~/.config/Kvantum /root/.config
Let’s take a look at this output:
env | grep -i "qt"
env | grep -i "qt"        ░▒▓ ✔ ▓▒░
QT_IM_MODULE=ibus
QT_QPA_PLATFORMTHEME=kvantum
QT_STYLE_OVERRIDE=kvantum
What happens if you launch it from the terminal like this:
btrfs-assistant-launcher
What happens if you launch it like this:
/usr/lib/garuda/pkexec-gui btrfs-assistant-bin
yeah , how do I set it as the default
I think I see what is happening here. This was actually fixed a couple months ago here:
But a new release hasn’t been tagged yet (@dalto, do you mind taking a look when you have a chance?), so the commits since the 1.8 tag have not been implemented yet.
In the meanwhile, you can get the updated version of Btrfs Assistant by installing the git version:
pacman -S btrfs-assistant-git
Using this version should resolve the issue.
thank you.
None of the above worked for me sadly. Including installing the latest btrfs-assistant. But, just knowing why they are not themed is almost good enough for me.
