I want to use AMD RAID and Manjaro compiles AHCI as builtin so if Garuda hs the Arch kernel then I'm set with many thing also that Garuda makes easy.
Yep. Even gets its kernel from the arch repos.
? during ? After install on metal, sure. During I think no
My translator failed.
But this topic is solved, open new after search for your questions, post also your search results.
garuda-chroot= yes
raid on install=IDK
As I said my translator failed.
