Is Garuda's package repository sync with ArchLinux's?
I heard that Plasma 5.22 is out yesterday as a beta package, so I go and search for it and I found that ArchLinux's repo already have Plasma 5.22 in the 'extra' repo.
https://archlinux.org/groups/x86_64/plasma/
So I want to ask:
Are Garuda Linux's repositories sync with ArchLinux's?
There is nothing like "Garuda Linux's repo". All Garuda uses is some Arch's repos plus chaotic-aur.
But I can't get Plasma update to 5.22... It is abnormal if as you say so
I am already running Plasma 5.22. Why not you? Because you haven't updated your system.
Sorry, how do you update your system?
https://wiki.archlinux.org/title/Pacman#Upgrading_packages
Special for Garuda Linux users :wink:
upd
Ok, watch: Here's the problem...
─jing at Jinglebell in ⌁
╰─λ sudo pacman -Qi plasma-workspace && sudo pacman -Syu
Version         : 5.21.5-1
Description     : KDE Plasma Workspace
Architecture    : x86_64
URL             : https://kde.org/plasma-desktop/
Licenses        : LGPL
Groups          : plasma
Provides        : None
Depends On      : knotifyconfig  libksysguard  ktexteditor  libqalculate  kde-cli-tools  appstream-qt
phonon-qt5  xorg-xrdb  xorg-xsetroot  kactivitymanagerd  kholidays  xorg-xmessage  milou
prison  kwin  plasma-integration  kdelibs4support  kpeople  kactivities-stats  libkscreen
kquickcharts  kuserfeedback
Optional Deps   : plasma-workspace-wallpapers: additional wallpapers [installed]
gpsd: GPS based geolocation [installed]
networkmanager-qt: IP based geolocation [installed]
kdepim-addons: displaying PIM events in the calendar
appmenu-gtk-module: global menu support for GTK2 and some GTK3 applications [installed]
qt5-virtualkeyboard: virtual keyboard support in lock screen [installed]
baloo: Baloo search runner [installed]
discover: manage applications installation from the launcher
ksysguard: data sources for the system monitor applets [installed]
Required By     : kde-servicemenus-encfs  kdeplasma-addons  kget  khotkeys  plasma-browser-integration
plasma-nm  plasma-pa  plasma-vault  plasma5-applets-eventcalendar
plasma5-applets-kpplemenu-git  plasma5-applets-latte-sidebar-button
plasma5-applets-window-appmenu  plasma5-applets-window-buttons
plasma5-applets-window-title  powerdevil  systemsettings
Optional For    : kde-cli-tools
Conflicts With  : None
Replaces        : None
Installed Size  : 38.52 MiB
Packager        : Antonio Rojas <[email protected]>
Build Date      : Tue 04 May 2021 21:58:17 +08
Install Date    : Thu 06 May 2021 11:14:47 +08
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
there is nothing to do
EDIT: I use upd command suggested by @SameExpert , and then now I am installing Plasma 5.22. I think I may probably use upd rather than sudo pacman -Syu after this...
Hm this is because, upd also refreshes mirrors. Sometimes some mirrors might take some time to be up to date and the mirrors you were using were not yet up to date.
So upd is a better practice in Garuda Linux :smiley:
Okay, thanks for the information :grin:
sudo pacman -Syyu
