I know there seems to be great and even GUI based tools for full backups, but are there tools that can provide me with something like a “Garuda Linux Config Backup”?
I wanna re-install my Garuda Dr460nized Gaming Version to fix my EFI Partition problem for good, but I definitely have some config changes that I forgot to document…
Therefore, I am searching for something that can backup/restore a config containing f.e. HDR settings, KDE/UI config, maybe even installed applications (diff) with config etc.
While writing this I already feel like a mad product owner person, asking for the impossible, but maybe our amazing Linux community has cooked something up that can help me here
You backup /.config and /.local. *Note .local has steam so you might want to exclude that from the backup. It also has some vary specific permissions on some folders so its best when you restore the folder to not just give the user full access as it will cause issues. best way to deal with this is mainly copy all the plasma stuff and things you added later.
You can check here to see where everything is. Plasma themes and plugins | Developer your after the location of user installed.
