Inxi of obviouslyace
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c3207fed-eb6b-4d0d-8114-915493c66c41 rw [email protected]
Type: Laptop System: Apple product: MacBookPro14,3 v: 1.0 serial: <filter>
Chassis: type: 9 v: Mac-551B86E5744E2388 serial: <filter>
Mobo: Apple model: Mac-551B86E5744E2388 v: MacBookPro14,3
serial: <filter> UEFI: Apple v: 447.80.3.0.0 date: 12/12/2021
ID-1: BAT0 charge: 61.7 Wh (97.3%) condition: 63.4/76.7 Wh (82.7%)
volts: 12.9 min: 11.5 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 234
Info: model: Intel Core i7-7700HQ socket: U3E1 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3621 high: 3801 min/max: 800/3800 base/boost: 2700/2800
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 25 MHz cores: 1: 3591 2: 3704 3: 3552 4: 3540 5: 3586 6: 3600
7: 3601 8: 3801 bogomips: 44798
Type: l1tf
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Apple driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0
chip-ID: 1002:67ef class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.0x18.7")
s-diag: 898mm (35.4")
Monitor-1: eDP res: 2880x1800 hz: 60 dpi: 221 size: 331x207mm (13.0x8.1")
diag: 390mm (15.4")
OpenGL: renderer: AMD Radeon RX Graphics (POLARIS11 DRM 3.44.0
5.16.16-zen1-1-zen LLVM 13.0.1)
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-2: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
type: USB driver: rtl88XXau bus-ID: 1-7:3 chip-ID: 0bda:8812 class-ID: 0000
IF: wlp0s20f0u7 state: up mac: <filter>
Local Storage: total: 233.76 GiB used: 30.19 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM0256L
size: 233.76 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CXS5EA0Q
temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 19d 19h cycles: 60,441
read-units: 45,704,539 [23.4 TB] written-units: 45,553,120 [23.3 TB]
ID-1: / raw-size: 37.6 GiB size: 37.6 GiB (100.00%) used: 30.19 GiB (80.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 300.4 MiB size: 299.5 MiB (99.72%)
used: 1.5 MiB (0.5%) fs: vfat block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-3: /home raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
used: 30.19 GiB (80.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Processes: 308 Uptime: 2m wakeups: 2 Memory: 15.52 GiB
used: 2.11 GiB (13.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: note: see --pkg pacman: 2136 lib: 408
inxi: 3.3.13
Garuda (2.5.6-2):
System install date:     2022-03-11
Last full system update: 2022-03-22
╭─[email protected] in ~ as 🧙 took 7s
╰─λ sudo garuda-inxi
[sudo] password for obviouslyace:
It's only your word against mine.
Speed (MHz): avg: 3633 high: 3800 min/max: 800/3800 base/boost: 2700/2800
ext-clock: 25 MHz cores: 1: 3577 2: 3601 3: 3713 4: 3646 5: 3800 6: 3568
7: 3600 8: 3566 bogomips: 44798
Type: l1tf
diag: 390mm (15.4")
Local Storage: total: 233.76 GiB used: 28.29 GiB (12.1%)
read-units: 45,705,019 [23.4 TB] written-units: 45,553,782 [23.3 TB]
ID-1: / raw-size: 37.6 GiB size: 37.6 GiB (100.00%) used: 28.29 GiB (75.2%)
maj-min: 259:3
used: 28.29 GiB (75.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
maj-min: 259:4
maj-min: 259:4
System Temperatures: cpu: 68.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Processes: 302 Uptime: 40m wakeups: 2 Memory: 15.52 GiB
used: 2.31 GiB (14.9%) Init: systemd v: 250 tool: systemctl Compilers:
inxi: 3.3.13
Garuda (2.5.6-2):
3 posts were merged into an existing topic: Cryptpad and Nextcloud shutting down soon :warning:
