Invalid MIT-MAGIC-COOKIE-1 key
I can't seem to connect to Display VIA SSH. Using the same display as Desktop.
garuda-inxi:
https://termbin.com/60fx
  Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=57122aaf-5f66-4abc-83d6-bf6287e05427 rw rootflags=subvol=@
    quiet rd.luks.uuid=45d1b06c-5944-4b2a-b044-3535488b69a7 quiet
    rd.luks.uuid=eab39f3b-b31f-4e4b-9941-cfed48ce9e51
    resume=/dev/mapper/luks-eab39f3b-b31f-4e4b-9941-cfed48ce9e51 loglevel=3
  Desktop: N/A wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 81DC v: Lenovo ideapad 330-15IKB
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15IKB
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: 8RCN58WW date: 05/19/2021
  ID-1: BAT0 charge: 30.0 Wh (100.0%) condition: 30.0/30.0 Wh (100.0%)
    volts: 8.5 min: 7.6 model: LGC L16C2PB2 type: Li-poly serial: <filter>
    status: charging
  Info: model: Intel Core i3-7130U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF2
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1666 high: 2700 min/max: 400/2700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 600 2: 2700 3: 665
    4: 2700 bogomips: 21599
  Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
  Device-2: Bison EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 5986:1127
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0
  Monitor-1: eDP-1 model: AU Optronics 0x41ec built: 2013 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: OpenGL Message: No GL data found on this system.
  API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0cf3:e500
  Local Storage: total: 577.55 GiB used: 9.68 GiB (1.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
    tech: SSD serial: <filter> fw-rev: 0004 scheme: GPT
    model: WD5000LPCX-24VHAT0 size: 465.76 GiB block-size: physical: 4096 B
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
    used: 9.68 GiB (9.4%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-45d1b06c-5944-4b2a-b044-3535488b69a7
    used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-eab39f3b-b31f-4e4b-9941-cfed48ce9e51
  ID-2: swap-2 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 42.0 C pch: 44.5 C mobo: N/A
  Processes: 237 Uptime: 1h 16m wakeups: 966 Memory: total: 8 GiB
  available: 7.67 GiB used: 3.49 GiB (45.6%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
  pm: pacman pkgs: 1295 libs: 357 tools: octopi,paru pm: rpm pkgs: 0
  Shell: Bash v: 5.1.16 running-in: sshd (SSH) inxi: 3.3.28
  System install date:     2023-07-22
  Last full system update: 2023-07-22 ↻
ssh_config has X11 forwarding enabled.
Welcome :slight_smile:
Which Garuda Linux desktop you use?
Reboot and check again.
I’m afraid I don’t understand the problem, the question.
I do not understand what you are trying to do either. This thread has some suggestions for the error you are getting though: ssh - "Invalid MIT-MAGIC-COOKIE-1 key" when trying to run program remotely - Unix & Linux Stack Exchange
Try
xhost +local:
before running it.
Or:
This one worked for me. So I’m leaving this answer here.
 export DISPLAY=:1.0
Or:
The value you’re using for DISPLAY is incorrect: if you don’t want to use SSH X forwarding, DISPLAY must indicate the IP address of your X server (the desktop you want to display programs on). On the remote, run
export DISPLAY=desktop:0
replacing desktop with your local hostname or IP address. You may also need to change your X server’s configuration to allow remote IP connections.
xhost +local:
Isn't ideal in terms of security, but it works! Thank you
