Intel ARC Alchemist GPU Power Limit/ Clock Speed and Fan Speed Configuration
Hello,
I do use Linux as a Power User from Windows since this year now and solved some Problems to run my OpenCl Programms over the new Intel ARC Alchemist GPUś with my own research over the time.
So long, so good.
But as a Windows User i did love the possibility to manage the Hardware Details with some Programms myself. Here we see mostly GPU Power Limits, Clock Speeds and Fan Speeds. With my work, i do need these Settings to optimizie all Parameters of my work in the way nearly to perfektion.
But i do not find out over the time, how i can do this all in Linux, here my lovely Distro is Garuda proofed over the time as the best ones for me, becouse all this little Details i do not have to know are inbuild. That is insane and the right way in my point of view.
Maybe there is a way to understand how i can manage the settings on my Intel Grafikcards, but i did not find anything helpfull in now more than 10 Month of research.
Is anybody out there who can build a little tool for us Dummies?
I am ready to spend this guy 100 Dollar for his work as a gift and thanks for the Work if it is done. Also i would write about that to share this in the world for all the other ones who want to manage their New Intel GPU under Linux (Arch/Garuda).
Thank you very much and feel free to ask me anything you would know.
Greetings and i hope we see us in other parts of this forum too, becouse i like this here to see.
Alucian
Welcome :slight_smile:
Nevertheless, even if you want to pay, it would be helpful if you post the garuda-inxi required by the template.
root=UUID=53b0da50-daf2-4581-9289-672d7526e89d rw rootflags=subvol=@
Type: Desktop Mobo: Acer model: Predator G3-605 serial: <superuser required>
UEFI: American Megatrends v: P11-C0 date: 04/01/2014
Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1810 high: 3395 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3395 2: 800 3: 800
4: 800 5: 3393 6: 3392 7: 800 8: 1100 bogomips: 54277
Device-1: Intel DG2 [Arc A770] driver: i915 v: kernel arch: Gen-12.7
code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 1 ports: active: DP-1 empty: DP-2, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 03:00.0 chip-ID: 8086:56a0
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: HP X27i serial: <filter> built: 2020 res: 2560x1440
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A770 Graphics (DG2)
device-ID: 8086:56a0 memory: 15.53 GiB unified: no
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: Intel
Arc A770 Graphics (DG2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:56a0 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Acer Incorporated ALI 8 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-2: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:4f90 class-ID: 0403
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 06:00.0 chip-ID: 168c:0034 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-1: Lite-On [] driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.5:3 chip-ID: 04ca:3006 class-ID: e001
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.1 lmp-v: 7
Local Storage: total: 987.41 GiB used: 28.08 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBU-SMS100S360GD
size: 55.9 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 06.9 scheme: GPT
model: WD10EADS-22M2B0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
scheme: MBR
ID-1: / raw-size: 55.6 GiB size: 55.6 GiB (100.00%) used: 28.08 GiB (50.5%)
ID-3: /home raw-size: 55.6 GiB size: 55.6 GiB (100.00%)
used: 28.08 GiB (50.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 55.6 GiB size: 55.6 GiB (100.00%)
ID-5: /var/tmp raw-size: 55.6 GiB size: 55.6 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 263 Uptime: 3h 26m wakeups: 0 Memory: total: 8 GiB
available: 7.68 GiB used: 4.26 GiB (55.5%) Init: systemd v: 254
pm: pacman pkgs: 1240 libs: 364 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-29
Last full system update: 2023-11-26
I hope that is what you need. I also have another Computer with three ARC Cards too, if you need this informations too that is no Problem for me. Thank you
This is my Workstation Computer:
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e545c5e8-d460-4811-aa1a-327495926db1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
serial: UEFI: American Megatrends v: 3805
date: 05/16/2018
Info: model: Intel Core i7-6700K bits: 64 type: MCP arch: Skylake-S
Topology: cpus: 1x cores: 4 smt: disabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 31999
Device-1: Intel DG2 [Arc A770] vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-3 empty: DP-1,
DP-2, DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 03:00.0
chip-ID: 8086:56a0 class-ID: 0300
Device-2: Intel DG2 [Arc A750] driver: i915 v: kernel arch: Gen-12.7
speed: 2.5 GT/s lanes: 1 ports: active: none empty: DP-5, DP-6, DP-7,
DP-8, HDMI-A-4, HDMI-A-5, HDMI-A-6 bus-ID: 07:00.0 chip-ID: 8086:56a1
Device-3: Intel DG2 [Arc A750] driver: i915 v: kernel arch: Gen-12.7
speed: 2.5 GT/s lanes: 1 ports: active: none empty: DP-10, DP-11, DP-12,
DP-9, HDMI-A-7, HDMI-A-8, HDMI-A-9 bus-ID: 0d:00.0 chip-ID: 8086:56a1
Monitor-1: DP-3 model: HP X27i serial: built: 2020 res: 2560x1440
device: 1 drv: iris device: 2 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: iris x11: drv: iris inactive: wayland
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: discrete-gpu name: Intel
device-ID: 8086:56a0 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: Intel Arc A750 Graphics (DG2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:56a1 surfaces: xcb,xlib device: 2 type: discrete-gpu
device-ID: 8086:56a1 surfaces: xcb,xlib device: 3 type: cpu name: llvmpipe
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
Device-2: Intel DG2 Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
Device-3: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 08:00.0
Device-4: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 0e:00.0
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 1.13 TiB used: 136.85 GiB (11.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: fw-rev: 3B4QFXO7 temp: 41.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW240H6
tech: SSD serial: fw-rev: RG21 scheme: GPT
used: 136.85 GiB (61.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 208 Uptime: 1d 1h 36m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.32 GiB (13.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1331 libs: 381 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-11-13
Last full system update: 2023-10-13
Unfortunately, I can’t help you with this, but it looks like you haven’t done an update for a while.
Just use
upd
in the terminal.
mhwd-kernel -li
Currently running: 6.6.2-AMD-znver3 (linux-amd-znver3)
The following kernels are installed in your system:
local/linux-amd-znver3 6.6.v.2-1
local/linux-zen 6.6.2.zen1-1
Oh. Ok. So i come back later if i know how to do that and share my information with you.
Thank you for the tip. I will do my updates now. :slight_smile:
Best wishes and thank you for the support!
Greetings
alucian
Please, don’t sign your posts — every post has your profile information attached to it. :slight_smile:
https://forum.garudalinux.org/faq
Ok. :slight_smile: I will remember this. :slight_smile:
