Hello Garuda users.
Since the migration of latte to integrated plasma KDE, I have a lot of problems with my terminal. The new one is my problem with Intellij and integrated terminal tool. When the termnal start I have the following error :
error: Unable to open universal variable file '/': Système de fichiers accessible en lecture seulement
Logo: getCharacterPixelDimensions() failed .%;888:8898898:
x;XxXB%89b8:b8%b88: *****@****
.8Xxd 8X:. ---------------------------
.8Xx; 8x:. OS: Garuda Linux x86_64
.tt8x .d x88; Host: 20TH001AFR ThinkPad P1 Gen 3
[email protected]; .db: [email protected]; Kernel: 6.1.12-zen1-1-zen
,tSXX° [email protected]; Uptime: 1 hour, 21 mins
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Battery: 92% [Charging]
,888S pd!
8X88/ q Packages: 1550 (pacman)[stable], 9 (snap)
8X88/ Shell: fish 3.6.0
GBB. Terminal: java
x%88 [email protected]@[email protected]@[email protected]@[email protected]@[email protected]@X.
dxXd dB8b8b8B8B08bB88b998888b88x. CPU: Intel(R) Core(TM) i9-10885H (16) @ 5.3 GHz
dxx8o [email protected]@;. GPU: Intel UHD Graphics
dx88 [email protected] GPU: NVIDIA Quadro T2000 Mobile / Max-Q
d:[email protected] Memory: 14.63 GiB / 30.98 GiB (47%)
.d988999889889899dd.
mkdir: impossible de créer le répertoire « /var/lib/snapd/snap/intellij-idea-ultimate/405/plugins/terminal/fish/completions »: Système de fichiers accessible en lecture seulement
mkdir: impossible de créer le répertoire « /var/lib/snapd/snap/intellij-idea-ultimate/405/plugins/terminal/fish/conf.d »: Système de fichiers accessible en lecture seulement
mkdir: impossible de créer le répertoire « /var/lib/snapd/snap/intellij-idea-ultimate/405/plugins/terminal/fish/functions »: Système de fichiers accessible en lecture seulement
Someone have an idea of what is going bad ?
One detail : integrated terminal start with fish system.
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f327471a-c329-462b-a1dc-fca7bb7580b2 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20TH001AFR v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH001AFR v: SDK0T08861 WIN
serial: <superuser required> UEFI: LENOVO v: N2VET26W (1.11 )
date: 11/16/2020
ID-1: BAT0 charge: 67.3 Wh (93.7%) condition: 71.8/80.4 Wh (89.3%)
volts: 17.4 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
status: charging cycles: 214
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3209 high: 5000 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 2400 2: 4955 3: 2400
4: 5000 5: 2400 6: 2400 7: 2400 8: 2400 9: 2400 10: 2400 11: 5000 12: 5000
13: 2400 14: 2400 15: 5000 16: 2400 bogomips: 76800
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-2
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fb8 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (39.96x11.22")
s-diag: 1054mm (41.51")
Monitor-1: DP-2 mapped: DP-1-1 note: disabled pos: left
model: Samsung C27F390 serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-2: eDP-1 pos: primary,right model-id: CSO 0x1500 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
IF-ID-1: br-1390277de6e6 state: down mac: <filter>
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 200.21 GiB (21.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 type: SSD serial: <filter> rev: 5108AGLA temp: 35.9 C scheme: GPT
ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
used: 200.17 GiB (34.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.6 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.98 GiB used: 10.17 GiB (32.8%)
System Temperatures: cpu: 51.0 C pch: 52.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2560 fan-2: 2363
Processes: 394 Uptime: 1h 25m wakeups: 245 Memory: 30.98 GiB
used: 17.48 GiB (56.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1560
pm: pacman pkgs: 1550 libs: 367 tools: octopi,paru pm: snap pkgs: 10
Shell: fish v: 3.6.0 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2021-11-16
Last full system update: 2023-02-21 ↻
Failed units: shadow.service
