:: installing jack2 (1.9.20-3) breaks dependency 'jack2=1.9.19' required by lib32-jack2
I tried to do what TNE suggested :
Second method:
Open a terminal, execute the command update , type in your password and let it finish the system update.
But then I'm getting
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
error: target not found: garuda-update
Refreshing mirrorlists using reflector, be patient please..
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirro
rlist
# When: 2022-01-25 10:53:10 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-01-25 10:53:01 UTC
# Last Check: 2022-01-25 10:49:48 UTC
[ some links ]
core 138,6 KiB 657 KiB/s 00:00 [####################################] 100%
extra 1555,2 KiB 3,38 MiB/s 00:00 [####################################] 100%
community 6,0 MiB 5,39 MiB/s 00:01 [####################################] 100%
Checking for keyring update before starting full system update..
error: target not found: garuda-hotfixes
error: target not found: chaotic-keyring
update
core is up to date
extra is up to date
chaotic-aur 1751,4 KiB 2,55 MiB/s 00:01 [####################################] 100%
--> Refreshing mirrorlists using reflector, please be patient..
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-01-25 11:08:46 UTC
# Retrieved: 2022-01-25 11:08:37 UTC
# Last Check: 2022-01-25 11:04:10 UTC
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux-br.com.br/archlinux/$repo/os/$arch
core 138,6 KiB 866 KiB/s 00:00 [####################################] 100%
extra 1555,2 KiB 5,54 MiB/s 00:00 [####################################] 100%
community 6,0 MiB 6,15 MiB/s 00:01 [####################################] 100%
chaotic-aur 1751,4 KiB 3,32 MiB/s 00:01 [####################################] 100%
:: Replace hwids with core/hwdata? [Y/n] n
resolving dependencies...
Can you send the output of pacman -Qu and the full file content of /etc/pacman.conf please? Something fishy is going on here for sure!
(Please use https://bin.garudalinux.org)
Well, I most certainly typed this command in my terminal.
FYI, I just tried again update remote fix, and it is doing a lot more than the first time I did.
So either I made a typo, or some other changes I've made in between made this command have a different effect.
