I am trying to install Garuda from live session. I get as far as the partition ( am doing this manually) I formatted the partition and tried to install and received a message saying Garuda needs a Fat32 Partition, EFI boot and boot flag and that I need to return to set this up on the Partition. When I try this the Next button is greyed out, so I can not proceed.
Could someone give some advice. I am confused.
Thank you,
Steve
Welcome spnoe
Have you read and are following
There are linked videos to help. I used Calamares and it worked faultlessly - is there a particular reason you prefer manual partitioning and install?
That is BTRFS
If you have a problem, please make your own thread and not hijack another.
Then you get individual attention.
Your problem may be different to that of the OP, diluting the effects of helpers.
The installer is telling you that you also need:
You need an EFI partition for the EFI boot files. Example as linked from the Garuda wiki page: https://wiki.archlinux.org/index.php/Partitioning#UEFI/GPT_layout_example
Thank you for your advice. I found the problem was in the BIOS. I needed to change the settings to UEFI only, then I was able to install.
Thanks
