I tried to do an update today, and it gave me the error noted above with four dependencies throwing the error:
- libavcodec.so=61-64
- libavformat.so=61-64
- libavutil.so=59-64
- libswscale.so=8-64
I have no idea why this broke all of a sudden, I have done no dependency modifications that I’m aware of, but could someone help me fix this please and thanks.
Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=febaf9ad-0482-4918-ab5a-fefa9211638a rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: MSI model: Z97S SLI Krait Edition (MS-7922) v: 2.0
serial: N/A uuid: 00000000-0000-0000-0000-d8cb8ac78ca0
UEFI: American Megatrends v: 10.7 date: 02/16/2016
Info: model: Intel Core i7-4790K socket: BGA1155 bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Speed (MHz): avg: 4401 min/max: 800/4400 base/boost: 4000/3800 scaling:
driver: intel_cpufreq governor: performance volts: 1.2 V ext-clock: 100 MHz
cores: 1: 4401 2: 4401 3: 4401 4: 4401 5: 4401 6: 4401 7: 4401 8: 4401
bogomips: 64003
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: ASUSTeK driver: nvidia
v: 580.82.09 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 model: ASUS VG27V serial: built: 2020 res:
mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.321 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 580.82.09
device-ID: 10de:2882 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22be
API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: n/a (root, process) with:
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 2.95 TiB used: 393.2 GiB (13.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial:
fw-rev: 4H scheme: GPT
SMART: yes state: enabled health: PASSED on: 344d 18h cycles: 140
read: 357.4 MiB written: 460.8 MiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
family: FireCuda 3.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: fw-rev: CC41 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 101d 5h cycles: 81
read: 10.34 TiB written: 5.05 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial:
fw-rev: 3B6Q temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 198d 1h cycles: 11
written: 2.97 TiB
used: 393.2 GiB (42.2%) fs: btrfs block-size: 4096 B dev: /dev/sdc2
maj-min: 8:34
used: 632 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sdc1 maj-min: 8:33
maj-min: 8:34
maj-min: 8:34
maj-min: 8:34
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 32 GiB available: 31.28 GiB used: 2.64 GiB (8.4%)
Processes: 298 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1993 libs: 576 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.3
Garuda (2.9.5-1):
System install date: 2025-03-23
Garuda release: 250308
Last full system update: 2025-10-01
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile
-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
Windows dual boot: Yes
— System Health Check Report —
24/24 checks run in 1.08 seconds ![]()
Powered by garuda-health
e
System health check passed. No issues found.
