Installing failled
Downloaded Gaaruda kde Linux. Installation failed.resync failed error code 11. Help developers.thankyou
It's not recommend to install on VM :wink:
and
Welcome in Garuda Linux Forum :slight_smile:
not in vm machine sir. installing on harddisk only... dual booting on win 10. now using lite edition it installs fine but ultimate edition is not installing . i think problem in file pakage . i indeed to download again . i will give a try . thank you.
Maybe you use better next generation of Garuda. Coming soon. :slight_smile:
KDE has some problem with Latte-Dock but that is not the rsync failure, maybe a memory problem, that also is solved :crossed_fingers: , in next ISO's.
I would suggest you checksum the ISO to be sure it doesn't contain errors.
If the ISO is error free, then I would suggest running Calamares in debug mode.
You can launch Calamares in debug mode from the terminal.
sudo calamares -d
Perhaps with detailed error logs @librewish could diagnose what your issue may be.
