Simple. I installed Mesa-TKG and didn’t see it was a devel branch. i wish to return to default mesa. I get dependency errors when it shoudl be managed automatically.
Garuda-INXI
Kernel: 6.13.3-arch1-1-znver2 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver2
root=UUID=1c3722df-cb74-4254-b3ac-590c0d1dbeaa rw rootflags=subvol=@
quiet amd_iommu=on iommu=pt
resume=UUID=0b7e6bb0-fbe7-402f-a475-ffee81795210 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop System: Gigabyte product: AB350-Gaming 3 v: N/A
Mobo: Gigabyte model: AB350-Gaming 3-CF serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F54d
date: 09/02/2024
Info: model: AMD Ryzen 5 4500 bits: 64 type: MT MCP arch: Zen 2 gen: 2
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3896 high: 4115 min/max: N/A cores: 1: 4086 2: 4108
3: 4084 4: 4087 5: 3593 6: 4085 7: 4087 8: 4093 9: 4115 10: 4080 11: 2744
12: 3593 bogomips: 86240
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,DVI-D-1,HDMI-A-1
empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 41.0 C
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2:3 chip-ID: 046d:085e
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5760x1080
display-ID: 0
Monitor-1: DP-1 pos: center model: ViewSonic VX2458-mhd serial: <filter>
built: 2019 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: DVI-D-1 pos: right model: Acer S231HL serial: <filter>
built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 pos: primary,left model: AOC 2370 serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 590 Series (radeonsi
polaris10 LLVM 19.1.7 DRM 3.60 6.13.3-arch1-1-znver2) device-ID: 1002:67df
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 590 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.13.3-arch1-1-znver2 status: kernel-api tools: N/A
vendor: Gigabyte driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Local Storage: total: 6.6 TiB used: 487.94 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: WDS250G2X0C-00L350 size: 232.89 GiB block-size: physical: 512 B
fw-rev: 101110WD temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000NM0053
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G00A
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 023
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000NM0053
ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT500MX500SSD1
ID-1: / raw-size: 199.88 GiB size: 199.88 GiB (100.00%)
used: 34.15 GiB (17.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.76 GiB size: 931.52 GiB (200.00%)
used: 229.36 GiB (24.6%) fs: btrfs dev: /dev/sdb maj-min: 8:16
ID-4: /var/log raw-size: 199.88 GiB size: 199.88 GiB (100.00%)
ID-5: /var/tmp raw-size: 199.88 GiB size: 199.88 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.21 GiB used: 55 MiB (0.2%) priority: 100
ID-2: swap-2 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 52.4 C mobo: 27.0 C gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0 gpu: amdgpu fan: 647
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.16 gpu: amdgpu watts: 49.10
Memory: total: 32 GiB available: 31.21 GiB used: 6.13 GiB (19.6%)
Processes: 463 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: 1793 pm: pacman pkgs: 1776 libs: 548 tools: octopi,paru
pm: flatpak pkgs: 17 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-02-14
Last full system update: 2025-02-21
resolving dependencies...
:: mesa-1:24.3.4-1 and mesa-tkg-git-25.1.0_devel.201792.98efca92079-1 are in conflict (libva-mesa-driver). Remove mesa-tkg-git? [y/N] y
:: lib32-mesa-1:24.3.4-1 and lib32-mesa-tkg-git-25.1.0_devel.201792.98efca92079-1 are in conflict (lib32-libva-mesa-driver). Remove lib32-mesa-tkg-git? [y/N] y
:: removing mesa-tkg-git breaks dependency 'vulkan-intel' required by garuda-video-linux-config
:: removing mesa-tkg-git breaks dependency 'vulkan-radeon' required by garuda-video-linux-config
:: removing mesa-tkg-git breaks dependency 'vulkan-mesa-layers' required by garuda-video-linux-config
:: removing mesa-tkg-git breaks dependency 'vulkan-swrast' required by garuda-video-linux-config
:: removing lib32-mesa-tkg-git breaks dependency 'lib32-vulkan-intel' required by garuda-video-linux-config
:: removing lib32-mesa-tkg-git breaks dependency 'lib32-vulkan-radeon' required by garuda-video-linux-config
:: removing lib32-mesa-tkg-git breaks dependency 'lib32-vulkan-mesa-layers' required by garuda-video-linux-config
:: removing mesa-tkg-git breaks dependency 'vulkan-driver' required by steam
:: removing lib32-mesa-tkg-git breaks dependency 'lib32-vulkan-driver' required by steam
:: removing mesa-tkg-git breaks dependency 'vulkan-driver' required by steam-native-runtime
:: removing lib32-mesa-tkg-git breaks dependency 'lib32-vulkan-driver' required by steam-native-runtime
