Here is my laptop specs:
CPU: I7 5500u
Ram 12gbs of ddr3 ram
gpu:gt840m 2gb
Brand HP Pavilion 15
Issue:
So recently, i tried installing the Garuda Linux .iso file with my USB flash drive.I downloaded it from source forge and uploaded it using etcher. Here is my file details:
(i cant upload the picture) So heres the directory: This PC - MISO_EFI usb - efi - boot - bootx64.efi. Nothing else.
Then, i rebooted my laptop, booted to the bios section and turned legacy to enabled also selecting usb rom drive as the first priority, and i clicked f10 to save and exit (security boot is disabled). After rebooting again it rebooted and i pressed f9. Somehow it shows the original name of my flash drive (ADATA flash drive) and it showed this message. What did i do wrong?
Selected boot drive did not authenticate, please press enter to continue
It would be thankful if you guys can help me with it.
Have you verified the checksum as per the below link.
In the link below you'll find also an alternative method to flash the USB (if you start from another Linux distro)
Christ, format your USB stick FAT32, download the garuda-dr460nized-linux-zen-210720.iso (size should be about 2.5 GB), then use Etcher to flash the ISO to the newly-formatted USB stick.
Make sure it is the .ISO file you download. We'll worry about checksums later.
